Multilanguage selector
How can i update <html lang="{{@site.lang}}"> with a language selector (select input) ?
Thanks.
Have you checked out the multi-language tutorial? You can do this using templates and collections.
https://ghost.org/tutorials/multi-language-content/
Yes, it works with posts but not with template, the html lang tag is not changed.
Have you found a way to switch language not from admin panel?
it’s now off line, I’m afraid
