Navigation manu elements
Hi there. my Theme is - Edition
How change showed elements in navigation bar from 5 elements to more? after 5 others going under submenu with three dots ( . . . )
Thanks for any help
Hi @Ilya_Terskov,
You will get this in assets/js/main.js file at line number 100.
You can change the number from 5 to any other number.
To run this file, you should have installed Node and Gulp on your local machine.
Thanks
