Newbie Question - Modifying basic theme
Hi everyone,
Brand new to Ghost, I feel it’s the perfect fit for me but before using it more I’d like to confirm/understand a basic concept. I check quite a big chunk of the documentation but didn’t find the question which is partly git related I guess.
I am using clever-cloud as host so I followed this tutorial:
In order to add the Casper site to content/theme I had to do:
git submodule add https://github.com/TryGhost/Casper.git casper
Now If I’d like to modify / customize this theme for me what is the best practice ? Shall I just modify my repo and push/merge to master or will my changes by always reset because I am using a submodule link ? Shall I remove this link and copy the casper repo directly and then modify it locally (but then I don’t get updates?)
Thanks a lot.
Typically you update themes by downloading them from the “Design” tab in your Ghost admin, editing the code, then re-uploading the ZIPped folder it into your Ghost admin.
I would suggest checking the Deploy Ghost Theme GitHub Action as an option.
