Hi devs,
Anyone had a look at only posting excerpts in the newsletter?
I’m having a go at it now as I figured it should be doable, but man, that is some convoluted code, caching and scheduling business going on…
All help and tips appreciated.
Thanks,
/Flemming
I’m wrapping up a solution for a client that uses the api to get the post content and then creates and schedules a newsletter from that.
Hi Cathy,
Hmm, that’s a bit more work than what I am looking for, but sounds like a good solution.
I was just hoping I could hard-code s.th “excerpt-ish” instead of “content-ish” in the sending process. - Just a quick fix until it gets added properly someday…
Well, continuing here, it seems all is located in @tryghost/email-service/lib/EmailRenderer.js => renderbody()
Thanks anyway,
/Flemming
Ad-hoc ninja-fix for self-hosted:
node_modules/@tryghost/email-service/lib/EmailRenderer.js
async renderPostBaseHtml(post) {
return post.get('custom_excerpt') || this.truncateHtml(post.get('plaintext'), 200, 105)
And in the template files,
node_modules/@tryghost/email-service/lib/email-templates/template.hbs
node_modules/@tryghost/email-service/lib/email-templates/template-old.hbs
…add some markup to click to continue reading after <!-- POST CONTENT END -->
<tr class="post-content-row">
<td class="{{classes.body}}">
<!-- POST CONTENT START -->
{{{html}}}
{{#if paywall}}
{{>paywall}}
<!-- Added from here -->
{{else}}
<p><center><a href="{{post.url}}" class="view-online-link">Click to continue reading in browser</a></center></p>
<!-- To here -->
{{/if}}
</td>
</tr>
-This of course will need to be redone for every version-update.
