The article pages on my blog don’t resolve if there is no trailing slash at the end of the URL. E.g. , Your first performance budget with Lighthouse versus Your first performance budget with Lighthouse
Ghost redirects all URL’s without a trailing slash to one with a trailing slash.
This is by design, as having only one url per page is better for SEO.
Oh how strange! I visited both links when you posted and they worked fine, but now I see the same thing in your screenshot.
When I do a hard refresh however it does load/redirect correctly
I’ve seen this behavior before when using service workers and they get corrupted - are you using a service worker on your site?
Ah okay! Yes I am using a service worker, and I thought it could be related but my implementation is similar to what I’ve used on other sites. I guess I need to figure out how to handle the redirects via the service worker as well. If there’s any documentation you have on this, that would be great!
I fixed it!
Wooo, glad you got it working!!
How did you solve it in the end, I’d be super interested to hear
Thanks!
Basically you were correct that the service worker was corrupted. I had pushed an update to the service worker over a month ago that had a fault in it, but when I updated the file to fix it a few weeks ago, the new version was never loaded.
I discovered yesterday that this was because Ghost has a pretty intense caching system, and the new versions of files aren’t loaded unless they have a query parameter on the file name. So, I fixed the issue by registering my service worker like this:
navigator.serviceWorker.register("/sw.js?refresh=true", {scope: "/"})
I think this will work even when I update the file again, but I may have to switch to using a versioned number instead if it doesn’t.
Awesome
If you find/think of something that can be improved with regards to caching and using service workers in Ghost, do let us know, or even open a PR
