Pagination Inside Tags
  • What’s your URL? This is the easiest way for others to debug your issue
    contentpk dot com
    3.0.2
  • What configuration?
    default
  • What browser?
    any
    none
    When we go to a particular tag, we see all posts in it, I would like to paginate it.
I believe you’re already answered here: Posts_per_page does not work (post attempt 2)
That was for the main page, I am asking about the tags page here
I’m also new to Ghost, but after going over all the documentation and tutorial pages, I believe this behavior will be the same for all index pages: homepage, tag, author, collection, channels, etc.
If you don’t want the infinite scroll behavior, the easiest path might be for you to switch to a theme that doesn’t have this feature to begin with, since this is not the default behavior of Ghost itself: it’s the Casper theme that’s doing the infinite scroll.
