I thought that featuring a post will stick it to the top but no! The latest post takes over the top space. Why? How can I change this behavior and fix what’s featured to the top?
If/how featured posts are used is up to the theme you’re using.
So how do I make my theme do this? I’m using casper
@barnabynagy I don’t know about Casper specifically, but have you tried using the routes.yaml “order” property?
For example, this is the one I distribute with my Weblog theme:
routes:
collections:
permalink: /{slug}/
template:
- index
order: featured desc, published_at desc
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
See: Ghost Themes - Dynamic URLs & Routing
You should be able to search for routes.yaml from your admin panel, download your existing one, make a backup copy, and then try putting this content in and uploading it and see if it does it. If it doesn’t work, revert.
This approach should work for Casper:
I’m not that technical… Can’t I just add a code injection?
You would think there would be a simple fix to this using code injection…
Code injection runs in the browser. Ordering is a server thing. The solution with routes.yaml above should do what you want, as long as you aren’t using source.
