- What’s your URL? This is the easiest way for others to help you
- What version of Ghost are you using? 4.47.4 but i am hosting my installation on Railway.app and i tried to update ghost to the latest and it failed to build
And
- How was Ghost installed and configured? Using a template link to the template
- What Node version, database, OS & browser are you using? latest
$ bin/create-config && node index.js CLOUDINARY_URL found, setting storage to cloudinary [2022-09-04 12:18:23] INFO Ghost is running in production... [2022-09-04 12:18:23] INFO Your site is now available on https://ghost-production-e72a.up.railway.app/ [2022-09-04 12:18:23] INFO Ctrl+C to shut down [2022-09-04 12:18:23] INFO Ghost server started in 0.663s [2022-09-04 12:18:25] WARN Database state requires initialisation. [2022-09-04 12:18:26] ERROR CREATE DATABASErailCHARACTER SET utf8mb4 COLLATE utf8mb4_general_ci; - Can't create database 'rail'; database exists CREATE DATABASErailCHARACTER SET utf8mb4 COLLATE utf8mb4_general_ci; - Can't create database 'rail'; database exists Error ID: 500 Error Code: DATABASE_CREATION_FAILED - What steps could someone else take to reproduce the issue you’re having?
1 Spin up this on Railway.app
2 go tobin/create-configand change the lines from 64 to 68 to a planetscale database
connection strings
3 after changing lines 64 to 68. Add a new line and copy and paste this text after line 68
ssl : {
// DO NOT DO THIS
// set up your ca correctly to trust the connection
rejectUnauthorized: false,
4 Deploy the app
