Po.et integration
It would be great if the Po.et blockchain project would be supported by Ghost.
Po.et describes it’s service as: “Po.et is a shared, open, universal ledger designed to record metadata and ownership information for digital creative assets”. So essentially you can record online that you own the information you write, which can be used when others copy your content. This is very useful for the more serious bloggers out there.
More information can be found here: https://www.po.et/publishers
There are quite a few integrations created already as well as language specific libraries such as: GitHub - JellyBool/po.et: Po.et PHP Integrations which should make integration straightforward…
