Problem with the node version
I have a problem with the installation (permission, nodejs version failed… etc).
So i’m using nodejs version 11.0.0.
I installed (as root user) nvm, to have multiple nodejs version. So I installed it, and install the 10.13.0 version. When I do node -v (root user) it tells me that I’ve got the version 10.13.0. So far so good. And then, when I switch on my nott root user, the nvm command won’t work, and when I do node -v it tells me 11.0.0, so the installation is impossible.
Who can I do to fix this?
Sorry for my bad english, I’m french!
Penkie.
Node 11 is not supported, as documented:
Yes, i already know. That’s why I installed nvm. Did you read my post? Haha ^^
Oh sorry, admittedly I did skip past the part after “i’m using nodejs version 11.0.0”
Have you already been through this?
Okey, i uninstalled NVM like said in the faq. And I’m trying to install it in a not root user. So I did su username, and then I’m running the installation for nvm in cd $HOME. But I’m getting an error:
You have $NVM_DIR set to “/root/.nvm”, but that directory does not exist. Check your profile files and environment.
Any suggestion?
Just to update. After maybe ~4 hours, I did it! I now have the right node version. BUT , I’m still having issue with the installation. Im getting this:
:heavy_multiplication_x: Downloading and installing Ghost v2.6.0
A ProcessError occurred.
and
warning ghost@2.6.0: The engine “cli” appears to be invalid.
Any ideas why?
Little update. I don’t know how or why, but I just deleted all the files and restarted the installation, and now all work fine. At an excepetion, I putted the blog adresse to my domain, and this domain name redirect to the IP of my VPS (on digital ocean). And when I go to my domain, it goes to my very simple index.html in /var/www/html/index.html. (maintenance page) and not the blog. The blog is located on /var/www/ghost.
I’am gonna end this topic because the problem is solved and I’ll start a new with my new problem. Thanks John for helping me out this problem.
