Hi all,
Just recently I moved from Wordpress to Ghost for a little blog that I made.
So far I like pretty much everything about Ghost. I just have an issue that drives me crazy.
Any upload in Ghost Admin fails with nginx & proxy_pass
This is my setup:
I run Ghost in Docker on a Debian 10 host. Port 2368 of the Ghost container is exposed on port 3001 of the docker host.
In a second container I run a nginx with modsecurity. Ports 80 & 443 exposed and using proxy_pass i forward traffic to Ghost.
Everything works perfectly fine except uploads in Gohst admin. It doesn’t matter if i try to upload a theme or a picture, all uploads fail.
When I do the same directly connecting to the ghost container on port 3001 everything, even uploads work well.
What’s your URL? This is the easiest way for others to debug your issue
Currently not reachable from the internet. -
3.17.1 -
What configuration?
Here’s my nginx conf
etc/nginx/conf.d# more ghost.conf
upstream ghost_upstream {
server ghost:3001;
keepalive 64;
server {
listen 80;
server_name myserver;
client_max_body_size 0;
chunked_transfer_encoding on;
location / {
proxy_http_version 1.1;
proxy_set_header X-Accel-Buffering: no;
proxy_ignore_headers Cache-Control;
proxy_set_header X-NginX-Proxy true;
proxy_ssl_session_reuse off;
proxy_set_header Host $host:$proxy_port;
proxy_read_timeout 900;
proxy_redirect off;
proxy_pass http://ghost:3001;
Here’s how i run docker:
docker run -d --restart unless-stopped --name ghost01 -e url=http://www.myserver.com -v /var/lib/docker/extvol/ghost01/var/lib/ghost/content:/var/lib/ghost/content -p 3001:2368 ghost
What browser?
Chrome -
Developer tools of in chrome i see that Link address http://www.myserver.com/ghost/api/v3/admin/images/upload/ fails ((failed) net::ERR_CONNECTION_RESET)
In the nginx error.log I find:
2020/05/28 12:23:16 [info] 44#44: *89 recv() failed (104: Connection reset by peer), client: 192.168.1.179, server: foodblog.life, request: “POST /ghost/api/v3/admin/images/upload/ HTTP/1.1”, host: “myserver”, referrer: “myserver/ghost/”
I tried different run options for both containers, different configs and options for nginx and Apache proxy_pass, different Browsers etc…I tried out Nginx and Apache, but i keep getting the same error with Nginx and with Apache.
Any help is very much appreciated.
Thanks
Sid
