Redirect causing an issue where slug repeats indefinitely
//I cannot share the URL here as it is currently under embargo. I can share privately via PM if needed.//
I am trying to redirect my homepage to a blog post for a “soft launch” of my website, so subscribers can sign up early without seeing the rest of the site as I continue to work on it. I have uploaded the redirect properly and Ghost has accepted it, but when I test it out, the redirect sends me to my site with the destination slug repeated indefinitely (i.e., /redirect-to/redirect-to/redirect-to/redirect-to/redirect-to/redirect-to/…etc).
Thanks in advance for your help!
  • What’s your URL? This is the easiest way for others to debug your issue
  • What configuration?
  • What browser?
Can you share the redirects file? I assume you’re just forwarding / to the new slug? That would then match on any request to your site, both / as well as /anything/, /anything/anything/, etc. – perfect loop :smiley:
The trick on redirects is to start the match with ^ and end it with $, which match the start and end of the path - that avoids most of the loopy behavior. So…
301 (or 302):
^/$: /some-blog-post/
ahhh you’re an angel, this is exactly what i did wrong. can i fix this with cathy’s suggestion below?
thank you so much cathy!!! implementing this now.
