I recently migrated my site (AWS lightsail) to self-hosted with docker. Is there an easy way to restore my backup to a new instance? I took these backups:
-rw-r–r-- 1 node node 8089600 Jul 22 19:16 2022-06-24-content.tar.gz
-rw-r–r-- 1 node node 70065 Jul 22 19:16 2022-06-24-database.sql.gz
-rw-r–r-- 1 node node 435 Jul 22 19:16 2022-06-24-json.gz
I did not see the docker container has ghost-cli installed, but it looks like it wouldn’t actually work right with docker since the containers are separated anyway (could be wrong).
I am using (nearly out-of-box) docker-compose now, with a MySQL container and the ghost container, so it looks like I could import the sql to MySQL manually, and I don’t really need the json, but the content file does not actually appear to be gzip’d properly…
tar -zxvf 2022-06-24-content.tar.gz
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
gzip -d also tells me:
gzip: invalid magic
But, just found out it is just a tar file which extracts file, so it never got gzip’d:
file 2022-06-24-content.tar.gz
2022-06-24-content.tar.gz: POSIX tar archive (GNU)
So, never mind, I think this is resolved, but leaving this here in case it helps save someone else some time.
