- What’s your URL?
It’s supposed to be https://hoanews.jongriffith.com
latest official docker image -
What configuration?
docker??? -
What browser?
chrome -
Proxy error -
I have Ghost running in a docker container on an Unraid server. The local address is http://192.168.1.140:2368 and it works.
I have Apache2 running on 192.168.1.200 and I have successfully deployed many other reverse proxies back to the “140” host. I’m having trouble with Ghost.
My first clue was that perhaps the config.production.json file in /var/lib/ghost needed to be edited. I did that, although I don’t know if I did it right.
The 2nd clue was that there’s something about x-forwarded-proto on the Reverse Proxy configuration information for Ghost. I’m not sure what this is nor how to implement it, or if I even need to.
My config.production.json is as follows:
"url": "http://localhost:2368",
"server": {
"port": 2368,
"host": "::"
"mail": {
"transport": "Direct"
"logging": {
"transports": [
"file",
"stdout"
"process": "systemd",
"paths": {
"contentPath": "/var/lib/ghost/content"
My apache configuration is as follows:
<VirtualHost 192.168.1.200:80 [fe80::41:f6ff:fe68:9051]:80>
SuexecUserGroup "#1002" "#1002"
ServerName hoanews.jongriffith.com
DocumentRoot /home/hoanews/public_html
ErrorLog /var/log/virtualmin/hoanews.jongriffith.com_error_log
CustomLog /var/log/virtualmin/hoanews.jongriffith.com_access_log combined
DirectoryIndex index.html index.htm index.php index.php4 index.php5
<Directory /home/hoanews/public_html>
Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch +ExecCGI
allow from all
AllowOverride All Options=ExecCGI,Includes,IncludesNOEXEC,Indexes,MultiViews,SymLinksIfOwnerMatch
Require all granted
AddType application/x-httpd-php .php
</Directory>
ProxyPreserveHost On
ProxyRequests off
ProxyVia On
ProxyPass / http://192.168.1.140:2368/
ProxyPassReverse / http://192.168.1.140:2368/
RewriteEngine on
RemoveHandler .php
RemoveHandler .php7.4
RedirectMatch ^/(?!.well-known)(.*)$ https://hoanews.jongriffith.com/$1
IPCCommTimeout 31
</VirtualHost>
<VirtualHost 192.168.1.200:443 [fe80::41:f6ff:fe68:9051]:443>
allow from all
Require all granted
</Directory>
ProxyRequests off
ProxyVia On
RemoveHandler .php
IPCCommTimeout 31
SSLCertificateFile /etc/letsencrypt/live/hoanews.jongriffith.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/hoanews.jongriffith.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
I would love to know if there’s someone who can help me get this running correctly.
The goal is to be able to hit https://hoanews.jongriffith.com for the main ghost blog.
Apache is on 192.168.1.200
Ghost is on 192.168.1.140:2368
One other note: If I change the “url” in the config.production.json file to “https://hoanews.jongriffith.com” chrome will redirect to this address but I still get the same connection error.
Also, if I add a parameter to the Docker configuration in Unraid so that URL is https://hoanews.jongriffith.com then the config.production.json changes the url to http://localhost:2368 and Chrome attempts to redirect to the https://hoanews.jongriffith.com url with the same error, which is this:
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request
Reason: Error reading from remote server
Apache/2.4.58 (Ubuntu) Server at hoanews.jongriffith.com Port 443
Any help would be awesome. I’m in over my head.
