I’m using the Ruby theme, and I’d like to adjust how the cards are being displayed on the front page, which I expected to find in index.hbs template, instead its just a loop over the posts. While the posts.hbs file is the template for posts that have been clicked on.
How do I modify the way in which it’s rendered at the index?
Would like to see the tag data on the same line as the title data. So it would look something like “Google - Is Chromebook Still a Thing”, in this example.
The way in which the post images get resized for this “baseball card” post, sometimes isn’t ideal. In the example I’m working with, it tends to crop faces. I think it’s cropping/aligning the image from the bottom going upwards, rather than centering it. My guess is the solution is somewhere in here: How To Scale and Crop Images with CSS object-fit | DigitalOcean .
