Hello, I installed Ghost Blog and have it working perfectly on my Ubuntu server.
What I’m trying to do is install “Pushnami” into my blog. They say to add 2 lines of code into the “head” which I did with code injections. But I need to serve 2 files they provided @ (mydomain(.)com/manifest.json) (mydomain(.)com/service-worker.js) - I’m not sure how to do about this and in what directory to upload the 2 files.
My blog is located @ : /var/www/ghost/mydomain(.)com
My NGINX Config
server {
listen 80;
listen [::]:80;
server_name mydomain.com;
root /var/www/ghost/mydomain.com/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
location / {
location ~ /.well-known {
allow all;
client_max_body_size 50m;
I know I need to edit this config file, just not sure how. It’s important that the .js and .json are served from mydomain.com/ and not mydomain.com/sub/file.json
Thank you in advance.
