Hello,
I’ve seen a few posts on the forum related to this, but haven’t been able to wrap my mind around it. I have content organized by tags into news and research. All of the tagged content shows up on the homepage.
Is there a way I can modify the home page to only show the say the 3 latest articles from news and the 3 latest articles from research?
Thanks!
Hey,
You can do this by using the get helper to request the posts. Then use a filter expression to filter specific posts by tag.
{{#get "posts" include="tags" filter="tag:home-features" as |feature|}}
{{#foreach feature}}
{{> "post-card"}}
{{/foreach}}
{{/get}}
@brightthemes has an excellent post that explains filter expressions well:
Thank you! As a question:
- would I need to download the YAML file for this, or is it possible via code injection?
- Also can I put in two get commands since I would want 3 from each?
- Will it automatically pull the most recent posts for the tag, or will I manually have to create some sort of date variable?
Best,
Piroune
Thank you! Can I ask another dumb question? I think I have to put the get command in the index.hbs file right? And if so (see below) - where in that should I put it? Any skeleton code you could provide would be massive.
Also really appreciate the help so far - you’re a legend!
index.hbs
{{!< default}}
{{!-- The tag above means: insert everything in this file
into the {body} of the default.hbs template --}}
<div class="site-header-content outer{{#match @custom.header_style "Left aligned"}} left-aligned{{/match}}{{#unless @custom.show_publication_cover}}{{#match @custom.header_style "Hidden"}} no-content{{/match}}{{/unless}}">
{{#if @custom.show_publication_cover}}
{{#if @site.cover_image}}
{{!-- This is a responsive image, it loads different sizes depending on device
https://medium.freecodecamp.org/a-guide-to-responsive-images-with-ready-to-use-templates-c400bd65c433 --}}
<img class="site-header-cover"
srcset="{{img_url @site.cover_image size="s"}} 300w,
{{img_url @site.cover_image size="m"}} 600w,
{{img_url @site.cover_image size="l"}} 1000w,
{{img_url @site.cover_image size="xl"}} 2000w"
sizes="100vw"
src="{{img_url @site.cover_image size="xl"}}"
alt="{{@site.title}}"
{{/if}}
{{/if}}
{{#match @custom.header_style "!=" "Hidden"}}
<div class="site-header-inner inner">
{{#unless @custom.show_logo_in_navigation}}
{{#if @site.logo}}
<img class="site-logo" src="{{@site.logo}}" alt="{{@site.title}}">
{{else}}
<h1 class="site-title">{{@site.title}}</h1>
{{/if}}
{{/unless}}
{{#if @site.description}}
<p class="site-description">{{@site.description}}</p>
{{/if}}
</div>
{{/match}}
</div>
{{!-- The main content area --}}
<main id="site-main" class="site-main outer">
<div class="inner posts">
<div class="post-feed">
{{#foreach posts}}
{{> "post-card"}}
{{/foreach}}
</div>
</div>
</main>
