Three small updates to the the “Posts” page in the admin section:
1 - In the title column, I would like to see the date of the post instead of the date of the post creation. I often post things with a date in the past (travel blog).
2 - Still in the title column, I would like to see the tags used for each post. It will be easier to spot a post with missing tags.
3 - Can we remove the “Sends” and “opens” columns when “Enable newsletter open-rate analytics” is OFF?
Tags used: show them on the same line as the author(s)/date.
Hide Send/Open if newsletter analytics off: yes.
However:
All of the column headers should be SORT actions (getting rid of the “Sort By” menu)
Date Created / Date Posted (updated) should BOTH be visible
If newsletter analytics is on, then calc avg and display Sent (##) Open (YY%).
BHAG
Replace the search (magnifying glass) with a filter function like on the members page. There’s less moving focus and attention BUT more importantly, it’s persistent. I can filter for a member, go to the member profile and make a change, then go back to the members page and the filter is still in effect. Until there is a batch action function this will make some forms of editing faster.
