I found these files:
/var/lib/docker/volumes/ghost_tinybird_files/_data/.tinyb
/var/lib/docker/volumes/ghost_tinybird_home/_data/.tinyb
So I can delete to reset the tinybird authentication so I could retry the steps. I still haven’t figured out why I get the error at step, docker compose run --rm tinybird-deploy
Thanks for reporting this. It looks like a change in Tinybird’s onboarding caused this to occur. They’re aware, and working on a fix now so it shouldn’t be a problem long term. Glad you were able to find this workaround for now!
