Tried to update Ghost and everything is broken :(
Do you think Node 20 could be the issue?
I did it from https://deb.nodesource.com/setup_18.x, not nvm
I can install Node 18 and try again.
It’s worth a try …
curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
sudo apt install nodejs --yes
sudo npm install ghost-cli@latest -g
So I got Node 18 and when tried to start there seems to be some kind of error connecting to the database, so that is something different:
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] INFO Ctrl+C to shut down
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] INFO Ghost server started in 1.326s
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] INFO Bootstrap client was closed.
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] ERROR connect ECONNREFUSED ::1:3306
May 15 20:52:13 blog node[2393]: connect ECONNREFUSED ::1:3306
May 15 20:52:13 blog node[2393]: "Unknown database error"
May 15 20:52:13 blog node[2393]: Error ID:
May 15 20:52:13 blog node[2393]:     500
May 15 20:52:13 blog node[2393]: Error Code:
May 15 20:52:13 blog node[2393]:     ECONNREFUSED
May 15 20:52:13 blog node[2393]: ----------------------------------------
May 15 20:52:13 blog node[2393]: Error: connect ECONNREFUSED ::1:3306
May 15 20:52:13 blog node[2393]:     at /var/www/ghost/versions/5.82.9/node_modules/knex-migrator/lib/database.js:57:19
May 15 20:52:13 blog node[2393]:     at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] WARN Ghost is shutting down
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] WARN Ghost has shut down
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] WARN Your site is now offline
May 15 20:52:13 blog node[2393]: [2024-05-15 20:52:13] WARN Ghost was running for a few seconds
May 15 20:52:13 blog systemd[1]: Stopping Ghost systemd service for blog: jvlobo-com...
May 15 20:52:14 blog node[2368]: /usr/lib/node_modules/ghost-cli/lib/process-manager.js:46
May 15 20:52:14 blog node[2368]:         throw error;
May 15 20:52:14 blog node[2368]:         ^
May 15 20:52:14 blog node[2368]: {
May 15 20:52:14 blog node[2368]:   message: {
May 15 20:52:14 blog node[2368]:     statusCode: 500,
May 15 20:52:14 blog node[2368]:     errorType: 'DatabaseError',
May 15 20:52:14 blog node[2368]:     level: 'critical',
May 15 20:52:14 blog node[2368]:     id: 500,
May 15 20:52:14 blog node[2368]:     help: 'Unknown database error',
May 15 20:52:14 blog node[2368]:     code: 'ECONNREFUSED',
May 15 20:52:14 blog node[2368]:     property: null,
May 15 20:52:14 blog node[2368]:     redirect: null,
May 15 20:52:14 blog node[2368]:     hideStack: false,
May 15 20:52:14 blog node[2368]:     message: 'connect ECONNREFUSED ::1:3306',
May 15 20:52:14 blog node[2368]:     name: 'DatabaseError',
May 15 20:52:14 blog node[2368]:     errno: -111,
May 15 20:52:14 blog node[2368]:     syscall: 'connect',
May 15 20:52:14 blog node[2368]:     address: '::1',
May 15 20:52:14 blog node[2368]:     port: 3306,
May 15 20:52:14 blog node[2368]:     fatal: true
May 15 20:52:14 blog node[2368]:   }
May 15 20:52:14 blog node[2368]: Node.js v18.20.2
May 15 20:52:14 blog systemd[1]: ghost_jvlobo-com.service: Main process exited, code=exited, status=1/FAILURE
May 15 20:52:14 blog systemd[1]: ghost_jvlobo-com.service: Failed with result 'exit-code'.
May 15 20:52:14 blog systemd[1]: Stopped Ghost systemd service for blog: jvlobo-com.
I’ll try to figure out what is happening now, MySQL is running:
Ok, I just saw this post and I changed from localhost to 127.0.0.1 on my config file and now it doesn’t throw that error anymore.
It starts with no errors, but if I try to get to my site I see:
If I restart sometimes I see the error:
502 Bad Gateway
nginx/1.18.0 (Ubuntu)
If I check the journal command I don’t see much, still the theme issue and this:
It doesn’t tell me much
It’s late here, so I’ll be brief. MySQL 8 uses sockets for authentication, so you need to change this to password for root and possibly the Ghost user or the database user specified in production.config.json.
Something like this.
sudo mysql
ALTER USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY '<password>';
QUIT;
You’re almost there!
Thanks.
That is done:
Screenshot 2024-05-16 at 13.06.18
Restarted Ghost but still the same. I don’t se anything new on the journal either.
Any ideas?
Thank you!
From the installation directory, try ghost run. Does the site load? You’ll also get output on the terminal.
Edit: Also, try ghost log --error.
ghost run seems to work fine (only throwing the theme warning)
However, if I run ghost log --error I get a database connection error over and over:
lobo@blog:/var/www/ghost$ ghost log --error
https://careers.ghost.org
+ sudo systemctl is-active ghost_jvlobo-com
[2024-05-16 10:57:09] ERROR
CODE: ECONNREFUSED
MESSAGE: connect ECONNREFUSED 127.0.0.1:3306
level: critical
Error: connect ECONNREFUSED 127.0.0.1:3306
[2024-05-16 10:57:12] ERROR
CODE: ECONNREFUSED
level: critical
[2024-05-16 10:57:16] ERROR
CODE: ECONNREFUSED
level: critical
Database seems to be running in the 3306 port and if I try to connect with the ghost database user and the password indicated in the Ghost config file I can access with no issues.
I’m not sure what is causing the issue while trying to connect to the database.
Please share your production.config.json file, and post with the <\> button in the forum post editor. Remove passwords, and other personal data, but keep the database user line intact.
This is the production.config.json
  "url": "https://url.com",
  "server": {
    "port": 2368,
    "host": "127.0.0.1"
  "database": {
    "client": "mysql",
    "connection": {
      "host": "127.0.0.1",
      "user": "ghost-454",
      "password": "password",
      "database": "ghost_prod"
  "mail": {
    "transport": "Direct"
  "logging": {
    "transports": [
      "file",
      "stdout"
  "process": "systemd",
  "paths": {
    "contentPath": "/var/www/ghost/content"
Just an update :thinking:
I was able to reach my site when starting the server again with ghost run (not sure what happened the previous time I ran that command but it was not loading).
I have also tried running it again with ghost start and in that case the site is not reachable (error 502).
But at least I can see it with ghost run and access the admin panel :open_mouth: (and the only error shown on console is the theme situation)
I note that you used root to connect to the database. Does sudo mysql -u ghost-454 -p work for you, too?
Yes it does, I only used root because I was doing the mysql_native_password.
But I can access with ghost-454 and the password specified on the config file with no problem.
Since I can access the website when starting with ghost run I enabled the default theme on the admin panel and I don’t get any theme errores now. But it still doesn’t work with ghost start.
With ghost run this is the log I get:
lobo@blog:/var/www/ghost$ ghost run
The `ghost run` command is used by the configured Ghost process manager and for debugging. If you're not running this to debug something, you should run `ghost start` instead.
+ sudo node current/index.js
[2024-05-16 13:21:00] INFO Ghost is running in production...
[2024-05-16 13:21:00] INFO Your site is now available on https://jvlobo.com/
[2024-05-16 13:21:00] INFO Ctrl+C to shut down
[2024-05-16 13:21:00] WARN Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED.
[2024-05-16 13:21:00] WARN Tries: 0
[2024-05-16 13:21:00] WARN Retrying...
[2024-05-16 13:21:00] WARN Tries: 1
[2024-05-16 13:21:00] WARN Tries: 2
[2024-05-16 13:21:00] INFO Ghost server started in 2.159s
[2024-05-16 13:21:00] INFO Database is in a ready state.
[2024-05-16 13:21:00] INFO Ghost database ready in 2.474s
[2024-05-16 13:21:01] WARN Missing mail.from config, falling back to a generated email address. Please update your config file and set a valid from address
[2024-05-16 13:21:05] INFO Adding offloaded job to the queue
[2024-05-16 13:21:05] INFO Scheduling job mentions-email-report at 26 18 * * * *. Next run on: Thu May 16 2024 14:18:26 GMT+0000 (Coordinated Universal Time)
[2024-05-16 13:21:06] INFO Adding offloaded job to the queue
[2024-05-16 13:21:06] INFO Scheduling job clean-expired-comped at 18 13 4 * * *. Next run on: Fri May 17 2024 04:13:18 GMT+0000 (Coordinated Universal Time)
[2024-05-16 13:21:06] INFO Scheduling job clean-tokens at 6 12 19 * * *. Next run on: Thu May 16 2024 19:12:06 GMT+0000 (Coordinated Universal Time)
[2024-05-16 13:21:06] INFO Ghost URL Service Ready in 8.099s
[2024-05-16 13:21:06] INFO Ghost booted in 8.111s
[2024-05-16 13:21:06] WARN Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED.
[2024-05-16 13:21:06] WARN Tries: 0
[2024-05-16 13:21:06] WARN Retrying...
[2024-05-16 13:21:06] INFO Scheduling job update-check at 1 35 5 * * *. Next run on: Fri May 17 2024 05:35:01 GMT+0000 (Coordinated Universal Time)
[2024-05-16 13:21:06] INFO Running milestone emails job on Sun May 19 2024 13:21:06 GMT+0000 (Coordinated Universal Time)
[2024-05-16 13:21:06] WARN Tries: 1
[2024-05-16 13:21:06] WARN Tries: 2
[2024-05-16 13:21:15] WARN {{#get}} helper took 273ms to complete
Error ID:
    2c174550-1387-11ef-8884-b98844fd4511
Error Code:
    SLOW_GET_HELPER
Details:
    api:          postsPublic.browse
    apiOptions:
      limit:   12
      include: authors
      context:
        member: null
    returnedRows: 12
[2024-05-16 13:21:15] INFO "GET /" 200 959ms
[2024-05-16 13:21:15] INFO "GET /assets/built/screen.css?v=d7853e827b" 200 19ms
[2024-05-16 13:21:15] INFO "GET /assets/built/source.js?v=d7853e827b" 200 22ms
[2024-05-16 13:21:15] INFO "GET /public/cards.min.js?v=d7853e827b" 200 23ms
[2024-05-16 13:21:15] INFO "GET /public/cards.min.css?v=d7853e827b" 200 23ms
And I can access the website… :thinking:
I have no idea why it doesn’t work with ghost start.
Any ideas?
Thank you!
Please enter this: ls /usr/lib/systemd/system/ghost*. This should provide the name of the Ghost service. Then, systemctl status <service-name>.
Apparently there is nothing ghost* in the system directory.
Earlier, I noticed that you had two users. I think this is part of the problem.
Run this, share the output.
id -u ghost
stat /var/www/ghost/content
This is the output:
lobo@blog:/var/www/ghost$ id -u ghost
999
lobo@blog:/var/www/ghost$ stat /var/www/ghost/content
  File: /var/www/ghost/content
  Size: 4096      	Blocks: 8          IO Block: 4096   directory
Device: fc01h/64513d	Inode: 512015      Links: 11
Access: (0775/drwxrwxr-x)  Uid: (  999/   ghost)   Gid: (  999/   ghost)
Access: 2024-05-15 20:30:24.911873358 +0000
Modify: 2024-05-15 18:01:29.888463312 +0000
Change: 2024-05-16 13:29:29.459272631 +0000
 Birth: -
That looks okay, but let’s do this, too.
sudo chown -R ghost:ghost /var/www/ghost/content
ghost setup systemd
Done:
lobo@blog:/var/www/ghost$ sudo chown -R ghost:ghost /var/www/ghost/content
[sudo] password for lobo:
lobo@blog:/var/www/ghost$ ghost setup systemd
Systemd service has already been set up. Skipping Systemd setup
ℹ Setting up Systemd [skipped]
No news tho, still not working with ghost start
How about creating the systemd file?
[Unit]
Description=Ghost systemd service for blog: jvlobo-com
Documentation=https://ghost.org/docs/
[Service]
Type=simple
WorkingDirectory=/var/www/ghost
User=999
Environment="NODE_ENV=production"
ExecStart=/usr/bin/node /usr/bin/ghost run
Restart=always
[Install]
WantedBy=multi-user.target
Place this in /usr/lib/systemd/system/ and save as ghost_jvlobo-com.service.
Now try sudo systemctl enable ghost_jvlobo-com.service and then sudo systemctl status ghost_jvlobo-com.service.
Ok, that is done:
