5.44.0 Could Not Communicate with ghost
I tried to change my site’s domain, and now ghost won’t start with a “Could not communicate with ghost” error.
here is the full log
    OS: Ubuntu, v20.04.4 LTS
    Node Version: v18.16.0
    Ghost Version: 5.44.0
    Ghost-CLI Version: 1.24.0
    Environment: production
    Command: 'ghost start'
Message: Could not communicate with Ghost
Suggestion: journalctl -u ghost_pearcemichal-com -n 50
Stack: Error: Could not communicate with Ghost
    at Server.<anonymous> (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:91:20)
    at Object.onceWrapper (node:events:627:28)
    at Server.emit (node:events:513:28)
    at emitCloseNT (node:net:2135:8)
    at process.processTicksAndRejections (node:internal/process/task_queues:81:21)
Also, when I try and do “ghost run”, there are a bunch of warning with the message
Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED.
ghost doctor reports no issues, and sudo nginx -t reports that the config is fine.
I tried messing around with different node version, but so far nothing has worked.
I also checked the other similar topics, and none of them were able to give me any useful info.
here is my config file
  "url": "https://pearcesjournal.com",
  "server": {
    "port": 2368,
    "host": "127.0.0.1"
  "database": {
    "client": "mysql",
    "connection": {
      "host": "localhost",
      "user": "root",
      "password": "GHOSTDBPASSWORD",
      "database": "ghost_prod"
  "mail": {
    "transport": "Direct"
  "logging": {
    "transports": [
      "file",
      "stdout"
  "process": "systemd",
  "paths": {
    "contentPath": "/var/www/pearcemichal/html/content"
  "imageOptimization": {
    "resize": false,
    "srcsets": false
  "bootstrap-socket": {
    "port": 8000,
    "host": "localhost"
And the NGINX config, which was generated using ghost config nginx
server {
    listen 80;
    listen [::]:80;
    server_name pearcesjournal.com;
    root /var/www/pearcemichal/html/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
    location / {
    location ~ /.well-known {
        allow all;
    client_max_body_size 50m;
let me know if there is any other info I need to supply.
It seems that the problem is from
    "port": 8000,
    "host": "localhost"
Try removing it and see what happens
Here seems like a similar issue
removing the bootstrap socket does not solve the issue
EDIT: also, if I remove the section, save the config, and try and start ghost, after sitting for awhile and failing to start, the bootstrap section has reappeared in the config.
I have made some progress
I re-setup certbot so the site has SSL, and now when I try to run the site, I get a different error, and it fails immediately, instead of stalling for ages.
new message:
Message: Ghost was able to start, but errored during boot with: connect ECONNREFUSED ::1:3306
Help: Unknown database error
log output
    Command: 'ghost setup'
Stack: Error: Ghost was able to start, but errored during boot with: connect ECONNREFUSED ::1:3306
    at Server.<anonymous> (/usr/local/lib/node_modules/ghost-cli/lib/utils/port-polling.js:73:28)
also, when I try to run sudo mysql I get an error
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
though I don’t know if this is relevant.
EDIT:
I tried what was suggested here, but it did not resolve the issue
Dead thread, but would love to hear how you fixed this. Facing the same issue, but I didn’t change my domain, it’s a new install
Kaushik, I don’t think the error you posted on the other thread is the same as this one. This one looked like a database error.
Ultimately I just reinstalled ghost + all dependencies from scratch.
