Turning the subscribe field from left to right
I would appreciate your help - my website is in Hebrew, so the registration field should also be from left to right, but it has not changed by transplanting the RTL code. Does anyone know a way to do this? (I am attaching a link to the website - it is right in the picture at the beginning of the website and the expression is that when you enter an email it is hidden under the button)
https://profcheck.ghost.io/
That’s the portal code. Make sure you have the site language set AND have portal translations on in settings > labs
If that doesn’t work, could you please update with a screenshot showing the problem?
Hebrew is not suported in Lab.
Here is a screen shot
To move the button to the left by adding this to code injection area
<style>
.form-button {left: 5px;}
</style>
Great news. Based on your screenshot, that text is not from the portal code, so you should be able to translate it, as long as you can edit the theme! :)
I injected the code but now the filed doesn’t responed
