I am using the image ghost:3.35.5-alpine with the database client mysql. I am using mysql database from digitalocean and I getting an error which preventing the container from starting.
[2020-10-18 21:19:29] ERROR create table `migrations_lock` (`lock_key` varchar(191) not null, `locked` boolean default '0', `acquired_at` datetime null, `released_at` datetime null) default character set utf8mb4 - UNKNOWN_CODE_PLEASE_REPORT: Unable to create or change a table without a primary key, when the system variable 'sql_require_primary_key' is set. Add a primary key to the table or unset this variable to avoid this message. Note that tables without a primary key can cause performance problems in row-based replication, so please consult your DBA before changing this setting.
Error ID:
9ba4fb70-1187-11eb-a9fc-a7a667559064
Error Code:
InternalServerError: create table `migrations_lock` (`lock_key` varchar(191) not null, `locked` boolean default '0', `acquired_at` datetime null, `released_at` datetime null) default character set utf8mb4 - UNKNOWN_CODE_PLEASE_REPORT: Unable to create or change a table without a primary key, when the system variable 'sql_require_primary_key' is set. Add a primary key to the table or unset this variable to avoid this message. Note that tables without a primary key can cause performance problems in row-based replication, so please consult your DBA before changing this setting.
at new GhostError (/var/lib/ghost/versions/3.20.2/node_modules/@tryghost/errors/lib/errors.js:10:26)
at /var/lib/ghost/versions/3.20.2/core/index.js:16:23
Error: UNKNOWN_CODE_PLEASE_REPORT: Unable to create or change a table without a primary key, when the system variable 'sql_require_primary_key' is set. Add a primary key to the table or unset this variable to avoid this message. Note that tables without a primary key can cause performance problems in row-based replication, so please consult your DBA before changing this setting.
at Query.Sequence._packetToError (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/sequences/Sequence.js:47:14)
at Query.ErrorPacket (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/sequences/Query.js:79:18)
at Protocol._parsePacket (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/Protocol.js:291:23)
at Parser._parsePacket (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/Parser.js:433:10)
at Parser.write (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/Parser.js:43:10)
at Protocol.write (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/Protocol.js:38:16)
at Socket.<anonymous> (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/Connection.js:88:28)
at Socket.<anonymous> (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/Connection.js:526:10)
at Socket.emit (events.js:315:20)
at addChunk (_stream_readable.js:295:12)
at readableAddChunk (_stream_readable.js:271:9)
at Socket.Readable.push (_stream_readable.js:212:10)
at TCP.onStreamRead (internal/stream_base_commons.js:186:23)
at Protocol._enqueue (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/protocol/Protocol.js:144:48)
at Connection.query (/var/lib/ghost/versions/3.20.2/node_modules/mysql/lib/Connection.js:198:25)
at /var/lib/ghost/versions/3.20.2/node_modules/knex/lib/dialects/mysql/index.js:135:18
at Promise._execute (/var/lib/ghost/versions/3.20.2/node_modules/bluebird/js/release/debuggability.js:384:9)
at Promise._resolveFromExecutor (/var/lib/ghost/versions/3.20.2/node_modules/bluebird/js/release/promise.js:518:18)
at new Promise (/var/lib/ghost/versions/3.20.2/node_modules/bluebird/js/release/promise.js:103:10)
at Client_MySQL._query (/var/lib/ghost/versions/3.20.2/node_modules/knex/lib/dialects/mysql/index.js:129:12)
at Client_MySQL.query (/var/lib/ghost/versions/3.20.2/node_modules/knex/lib/client.js:169:17)
at Runner.query (/var/lib/ghost/versions/3.20.2/node_modules/knex/lib/runner.js:134:36)
at Runner.queryArray (/var/lib/ghost/versions/3.20.2/node_modules/knex/lib/runner.js:231:31)
at /var/lib/ghost/versions/3.20.2/node_modules/knex/lib/runner.js:38:25
at /var/lib/ghost/versions/3.20.2/node_modules/knex/lib/runner.js:260:24
Digitalocean only allows setting the sql_require_primary_key value to OFF per session. I tried creating the table manually, but then I get an error saying âan existing migration is in progressâ even though the table is empty.
Technical details:
- Ghost Version: 3.35.5
- Database: MySQL v8
