Unable to Update Post Content Using Admin API - 2024
Hello everyone,
I’ve been trying to update the content of my post, but unfortunately, I’ve hit a wall.
Here is the Python function I’m using to update the post:
def updateGhostPost(post_id, html):
    # Generate an authentication token
    token = generate_token(api_key)
    # Set the headers for the PUT request
    headers = {
        'Authorization': 'Ghost {}'.format(token),
        'Content-Type': 'application/json'
    # Construct the URL for updating the post
    update_url = api_url + f'/api/admin/posts/{post_id}/'
    # Construct the URL to get the current post data
    get_url = api_url + f'/api/content/posts/{post_id}/?key={api_content_key}'
    # Set the headers for the GET request
    headersGet = {
    # Send a GET request to retrieve the current post data
    response = requests.get(get_url, headers=headersGet)
    # Parse the response JSON to get the post's current updated_at timestamp
    dataResponse = response.json()['posts'][0]
    updated_at = dataResponse['updated_at']
    # Prepare the data for the PUT request with the new HTML content and timestamp
    data = {
        'posts': [{
            'html': html,
            'updated_at': updated_at,
    # Log the update attempt with the post ID
    print(f"Actualizando post con ID {post_id}")
    # Send a PUT request to update the post content
    response = requests.put(update_url, json=data, headers=headers)
    # Print the status code of the PUT request
    print("Status Code:", response.status_code)
    # Return True if the update is successful
    return True
The requests.put call returns a status code of 200 , indicating success, but the HTML content does not update.
Has anyone experienced a similar issue or have any suggestions on how to resolve this? I would greatly appreciate any help or guidance you can provide.
Thank you in advance!
Best regards
You’re missing source:html, which is required any time you are passing the post body as html instead of lexical.
Hi Cathy,
Thank you so much for your response! Your suggestion worked perfectly for me. Here’s the code snippet I used:
    update_url = api_url + f'/api/admin/posts/{post_id}/?source=html'
