- What version of Ghost are you using? 3.4.2
- What configuration? ghost+heroku+github (SNathJr/ghost-on-heroku - Buttons - Heroku Elements)
- What browser? chrome/firefox
- What errors or information do you see in the console? (see below)
- What steps could someone else take to reproduce the issue you’re having? (see below)
Details
I have followed the following to work on the Ghost Blog, Github+Herok+Ghost > One click install, it installed the V3 ghost on the server. however i am unable to upgrade to latest version of ghost i.e. version 4.2.0
please can you guide me what i am missing.
Steps i have done so far as follows
a) Installation >Github link
b) Local Copy >> saved on c drive >> C:\ghost-on-heroku screenshot below
i have run the following commands so far, and getting this error.
CMD
C:>heroku login C:>cd ghost-on-heroku
C:\ghost-on-heroku>heroku git:clone -a project name Cloning into ‘project name’… remote: Counting objects: 1727, done. remote: Compressing objects: 100% (1091/1091), done. remote: Total 1727 (delta 554), reused 1717 (delta 547) eceiving objects: 89% (1538/1727), 11. Receiving objects: 100% (1727/1727), 11.59 MiB | 3.62 MiB/s, done. Resolving deltas: 100% (554/554), done.
C:\ghost-on-heroku>cd projectname
C:\ghost-on-heroku\projectname>npm outdated
Package Current Wanted Latest Location Depended by
ghost MISSING 3.42.4 4.2.0 - projectname
ghost-storage-adapter-s3 MISSING 2.8.0 2.8.0 - projectname
ghost-storage-cloudinary MISSING 2.1.5 2.1.5 - projectname
ghost-webdav-storage-adapter MISSING 0.3.5 0.4.1 - projectname
mysql MISSING 2.18.1 2.18.1 - projectname
C:\ghost-on-heroku\projectname>ghost -v Ghost-CLI version: 1.16.3
C:\ghost-on-heroku\projectname>npm -v 7.8.0
C:\ghost-on-heroku\projectname>node -v v10.24.1
C:\ghost-on-heroku\projectname>npm upgrade ghost
added 1328 packages, and audited 1763 packages in 48s
1 package is looking for funding run npm fund
for details
20 vulnerabilities (5 low, 3 moderate, 12 high)
To address issues that do not require attention, run: npm audit fix
To address all issues (including breaking changes), run: npm audit fix --force
Run npm audit
for details.
C:\ghost-on-heroku\projectname>npm audit fix --force npm WARN using --force Recommended protections disabled. npm WARN audit Updating ghost to 0.11.14,which is a SemVer major change. npm WARN audit Updating ghost-webdav-storage-adapter to 0.4.1,which is a SemVer major change. npm WARN deprecated webdav@3.6.2: WebDAV 3.x is deprecated: Please upgrade to v4. npm ERR! code 231 npm ERR! path C:\ghost-on-heroku\projectname\node_modules\ghost npm ERR! command failed npm ERR! command C:\Windows\system32\cmd.exe /d /s /c node core/server/utils/npm/preinstall.js npm ERR! ERROR: Unsupported version of Node npm ERR! Ghost supports LTS Node versions: ^6.9.0 npm ERR! You are currently using version: 10.24.1 npm ERR! This check can be overridden, see https://docs.ghost.org/v0.11/docs/supported-node-versions for more info
npm ERR! A complete log of this run can be found in: npm ERR! C:\Users\s\AppData\Local\npm-cache_logs\2021-04-08T11_-debug.log
please help me what i would need to get the blog updated to ghost 4.2.0 (i have tried with installing multiple nodejs version, i.e. version 12, version 14 etc, but may be i am doing something wrong)
