Unable to upgrade Ghost from v3.16.1 to v3.18.0
Hi Everyone,
I’ve tried to update my ghost blog (v3.16.1 + Sqlite3) to the last release (3.18.0) but it failed.
Furthermore ghost-cli seems to be unable to rollback :thinking:
  • Any idea of what’s happened ?
STEPS
  • sudo npm install -g ghost-cli@latest
  • ghost update
? Unable to upgrade Ghost from v3.16.1 to v3.18.0. Would you like to revert back to v3.16.1? Yes
+ sudo systemctl is-active ghost_mydomain-com
+ sudo systemctl reset-failed ghost_mydomain-com
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking for available migrations
ℹ Downloading and updating Ghost [skipped]
+ sudo /srv//mydomaincom/current/node_modules/.bin/knex-migrator-rollback --force --v 3.16.1 --mgpath /srv//mydomaincom/current
✖ Rolling back database migrations
A ProcessError occurred.
Message: The database migration in Ghost encountered an error.
Help: https://ghost.org/faq/upgrade-to-ghost-2-0/#what-to-do-when-an-upgrade-fails
Suggestion: ghost update --rollback
    OS: Ubuntu, v18.04.4 LTS
    Node Version: v12.17.0
    Ghost Version: 3.18.0
    Ghost-CLI Version: 1.14.0
    Environment: production
    Command: 'ghost update'
Message: SQLITE_CANTOPEN: unable to open database file
Help: Unknown database error
Suggestion: journalctl -u ghost_mydomain-com -n 50
Stack: Error: SQLITE_CANTOPEN: unable to open database file
    at Server.<anonymous> (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:38:28)
    at Object.onceWrapper (events.js:421:28)
    at Server.emit (events.js:315:20)
    at emitCloseNT (net.js:1655:8)
    at processTicksAndRejections (internal/process/task_queues.js:83:21)
Run “Ghost Start”
+ sudo systemctl is-active ghost_mydomaincom
✔ Validating config
+ sudo systemctl start ghost_mydomaincom
+ sudo systemctl stop ghost_mydomaincom
✖ Starting Ghost: mydomaincom
A GhostError occurred.
Suggestion: journalctl -u ghost_mydomaincom -n 50
    Command: 'ghost start'
Debug log
Thank you in advance !
We just fixed this in 3.18.1 so please update using Ghost-CLI :slightly_smiling_face:
Hi @Hannah
I did it but it failed :frowning_face:
What should I do ?
/usr/bin/ghost -> /usr/lib/node_modules/ghost-cli/bin/ghost
+ ghost-cli@1.14.0
updated 1 package in 12.047s
sudo npm install -g npm
/usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
/usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
+ npm@6.14.5
updated 5 packages in 15.417s
ghost update
✔ Downloading and updating Ghost to v3.18.1
✔ Stopping Ghost
✔ Linking latest Ghost and recording versions
✖ Restarting Ghost
    Ghost Version: 3.18.1
Debug log
Thank you for your help !
Sorry I saw the 3.18 and the line saying “Message: The database migration in Ghost encountered an error.” and assumed it was the bug we just fixed.
Scrolling down further I see
Which is pretty clear about what’s happening, just not giving a reason why.
Only thing I can see that might be a clue is the double slash in your path here - maybe that’s preventing the file from being readable/opened by sqlite?
Sorry he double slash in the path is a copy/past error !
Yes it’s weird, error is clear but not verbose and I can’t rollback to release 3.16.1
I’m cursed with updates :see_no_evil: :sweat_smile:
+ sudo /srv/mydomaincom/current/node_modules/.bin/knex-migrator-rollback --force --v 3.18.0 --mgpath /srv/mydomaincom/current
Debug
    Command: 'ghost update --rollback'
--------------- stderr ---------------
[2020-06-02 19:07:32] ERROR SQLITE_CANTOPEN: unable to open database file
ghost doctor
✔ Checking logged in user
✔ Checking operating system compatibility
? Sudo Password [hidden]
✔ Validating config
Hi @Hannah
I found the issue !
To solve it I have to set the absolute path on the database path in the “config.production.json” file.
Before
  "database": {
    "client": "sqlite3",
    "connection": {
      "filename": "./content/data/ghost.db"
Now
  "database": {
    "connection": {
      "filename": "/srv/mydomaincom/content/data/ghost.db"
Then run ghost start
Many thanks, Whys, you just saved my evening ! Your solution just work perfectly !
Hi Ghost Team,
I’ve updated another ghost blog instance and faced the same issue so I decided to do a fresh install to understand the problem. :thinking:
It seems that there is a “bug/regression” when installing Ghost + Sqlite3, you need to specify the absolute “Database path” post install in the config.production.json.
I hope this help !
Whys
Hey @Whys, thanks for the feedback! There was an edge-case in the Ghost CLI which has been fixed, but not yet released :slight_smile:
Ghost CLI v1.14.1 has been released which fixes this issue :smiley:
Yes I’ve tested it, thank you !
