Hi, i wonder if someone can help me with an error that popped up after updating from version 4.9.3 to 4.9.4.
Maria-db version: 10.5.11
Before doing this update i first updated my nodejs version to 14, updated npm itself and updated the ghost-cli npm module. The update itself was succesful without any errors till starting the ghost instance.
Before i was using nodejs version 10 and i had no problems at all.
Under here i’ve tried to collect alle the logs i got and replaced my domain with kb.domain.nl, i hope someone is able to tell me where the problem is and how i can fix this, thanks for reading this and taking a look.
Greetings,
Lucas Ridder
ghost start log:
kennisbank@44:/var/www/ghost$ ghost start
- sudo systemctl is-active ghost_kb-domain-nl
Checking system Node.js version - found v14.17.2
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking systemd unit file
Checking systemd node version - found v14.17.2
- sudo systemctl start ghost_kb-domain-nl
- sudo systemctl stop ghost_kb-domain-nl
Starting Ghost: kb-domain-nl
A GhostError occurred.Message: Ghost was able to start, but errored during boot with: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
Suggestion: journalctl -u ghost_kb-domain-nl -n 50Debug Information:
OS: Ubuntu, v18.04.5 LTS
Node Version: v14.17.2
Ghost Version: 4.9.4
Ghost-CLI Version: 1.17.3
Environment: production
Command: ‘ghost start’
debug log file:
Suggestion: journalctl -u ghost_kb-ghost-nl -n 50
Stack: Error: Ghost was able to start, but errored during boot with: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
at Server. (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:73:28)
at Object.onceWrapper (events.js:481:28)
at Server.emit (events.js:375:28)
at emitCloseNT (net.js:1661:8)
at processTicksAndRejections (internal/process/task_queues.js:81:21)
journalctl logs:
Jul 17 01:30:28 P44 systemd[1]: Started Ghost systemd service for blog: kb-domain-nl.
Jul 17 01:30:29 P44 node[982]: - Inspecting operating system
Jul 17 01:30:29 P44 node[982]: [2021-07-16 23:30:29] INFO Ghost is running in production…
Jul 17 01:30:29 P44 node[982]: [2021-07-16 23:30:29] INFO Your site is now available on https://kb.domain.nl/
Jul 17 01:30:29 P44 node[982]: [2021-07-16 23:30:29] INFO Ctrl+C to shut down
Jul 17 01:30:29 P44 node[982]: [2021-07-16 23:30:29] INFO Ghost server started in 0.204s
Jul 17 01:30:29 P44 node[982]: [2021-07-16 23:30:29] INFO Bootstrap client was closed.
Jul 17 01:30:29 P44 node[982]: [2021-07-16 23:30:29] WARN Database state requires migration.
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] INFO Creating database backup
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] INFO Database backup written to: /var/www/ghost/content/data/redacted.ghost.2021-07-16-23-30-3
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] INFO Adding posts_meta.feature_image_caption column
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] INFO Updating all member “comped” statuses to “paid”
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Removing email_batches.member_segment column - skipping as table is correct
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Skipping dropping table: products_benefits - table does not exist
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Skipping dropping table: benefits - table does not exist
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] ERROR Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
Jul 17 01:30:30 P44 node[982]: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
Jul 17 01:30:30 P44 node[982]: "OuterError: alter tableposts_metaaddfeature_image_captiontext null - ER_TOO_BIG_ROWSIZE: Row size too large. The maximum row size for the used table type, not
Jul 17 01:30:30 P44 node[982]: Error ID:
Jul 17 01:30:30 P44 node[982]: 400
Jul 17 01:30:30 P44 node[982]: ----------------------------------------
Jul 17 01:30:30 P44 node[982]: InternalServerError: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
Jul 17 01:30:30 P44 node[982]: at DatabaseStateManager.makeReady (/var/www/ghost/versions/4.9.4/core/server/data/db/state-manager.js:98:32)
Jul 17 01:30:30 P44 node[982]: at async initDatabase (/var/www/ghost/versions/4.9.4/core/boot.js:57:5)
Jul 17 01:30:30 P44 node[982]: at async bootGhost (/var/www/ghost/versions/4.9.4/core/boot.js:320:9)
Jul 17 01:30:30 P44 node[982]: RollbackError: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
Jul 17 01:30:30 P44 node[982]: at RollbackError.KnexMigrateError (/var/www/ghost/versions/4.9.4/node_modules/knex-migrator/lib/errors.js:7:26)
Jul 17 01:30:30 P44 node[982]: at new RollbackError (/var/www/ghost/versions/4.9.4/node_modules/knex-migrator/lib/errors.js:31:26)
Jul 17 01:30:30 P44 node[982]: at /var/www/ghost/versions/4.9.4/node_modules/knex-migrator/lib/index.js:440:23
Jul 17 01:30:30 P44 node[982]: at tryCatcher (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/util.js:16:23)
Jul 17 01:30:30 P44 node[982]: at Promise._settlePromiseFromHandler (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/promise.js:547:31)
Jul 17 01:30:30 P44 node[982]: at Promise._settlePromise (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/promise.js:604:18)
Jul 17 01:30:30 P44 node[982]: at Promise._settlePromise0 (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/promise.js:649:10)
Jul 17 01:30:30 P44 node[982]: at Promise._settlePromises (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/promise.js:725:18)
Jul 17 01:30:30 P44 node[982]: at _drainQueueStep (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/async.js:93:12)
Jul 17 01:30:30 P44 node[982]: at _drainQueue (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/async.js:86:9)
Jul 17 01:30:30 P44 node[982]: at Async._drainQueues (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/async.js:102:5)
Jul 17 01:30:30 P44 node[982]: at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/4.9.4/node_modules/bluebird/js/release/async.js:15:14)
Jul 17 01:30:30 P44 node[982]: at processImmediate (internal/timers.js:464:21)
Jul 17 01:30:30 P44 node[982]: Error: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist
Jul 17 01:30:30 P44 node[982]: at down (/var/www/ghost/versions/4.9.4/core/server/data/migrations/utils.js:174:23)
Jul 17 01:30:30 P44 node[982]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
Jul 17 01:30:30 P44 node[982]: at async Object.down (/var/www/ghost/versions/4.9.4/core/server/data/migrations/utils.js:281:13)
Jul 17 01:30:30 P44 node[982]: at async Object.down (/var/www/ghost/versions/4.9.4/core/server/data/migrations/utils.js:305:17)
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Ghost is shutting down
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Ghost has shut down
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Your site is now offline
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] WARN Ghost was running for a few seconds
Jul 17 01:30:30 P44 node[982]: [2021-07-16 23:30:30] INFO Bootstrap client was closed.
Jul 17 01:30:30 P44 systemd[1]: Stopping Ghost systemd service for blog: kb-domain-nl…
Jul 17 01:30:31 P44 node[982]: /usr/lib/node_modules/ghost-cli/lib/process-manager.js:46
Jul 17 01:30:31 P44 node[982]: throw error;
Jul 17 01:30:31 P44 node[982]: ^
Jul 17 01:30:31 P44 node[982]: {
Jul 17 01:30:31 P44 node[982]: message: ‘Ghost was able to start, but errored during boot with: Cannot remove permission(Reset all passwords) from role(Administrator) - permission does not exist’
Jul 17 01:30:31 P44 node[982]: }
