Update to 2.0 - Ghost-CLI was unable to load versions from Yarn
Update from Ghost 1.25.5 to latest 2.0 – I’ve already done a migration from 0.11.x, and things seem to be running fine in there, but I get this failure running ghost update:
Running sudo command: systemctl is-active ghost_cookingconcerts-com
:heavy_check_mark: Checking system Node.js version
:heavy_check_mark: Ensuring user is not logged in as ghost user
:heavy_check_mark: Checking if logged in user is directory owner
:heavy_check_mark: Checking folder permissions
:heavy_check_mark: Checking file permissions
:heavy_check_mark: Checking content folder ownership
:heavy_check_mark: Checking for available migrations
:heavy_multiplication_x: Checking for latest Ghost version
A CliError occurred.
Message: Ghost-CLI was unable to load versions from Yarn.
OS: Ubuntu, v16.04
Node Version: v6.14.4
Ghost-CLI Version: 1.9.2
Environment: production
Command: ‘ghost update’
Please refer to https://docs.ghost.org/v1/docs/troubleshooting#section-cli-errors for troubleshooting.
I’m using a sqlite3 db. Migrating all of this stuff over from a different debian installation to Ubuntu, but this is basically a scratch config after installing a 1.25.5 version via ghost-cli.
I will be running two ghost instances on this server – one of them, already at 2.0.3, was configured already in a separate directory, and it was running fine – that blog didn’t have much content to migrate so I just recreated it by hand.
Has anyone seen this error before? Is it perhaps just a temporary thing with Yarn?
I just got this while trying to update to the latest version.
➜  ghost ghost update
✔ Checking for available migrations
✖ Checking for latest Ghost version
  OS: Mac OS X, v10.13.6
  Node Version: v8.9.1
  Environment: development
  Command: 'ghost update'
➜  ghost ghost -v
Ghost-CLI version: 1.9.2
Ghost Version (at ~/www/ghost): 2.0.3
Looks like it was a temporary issue. I tried again and it works.
Yep. Works for me now as well. And now I’m up to 2.1.0. :smiley:
