It was using separate volumes that solved the issue for me. I would prefer to use mounts, so I am going to try the above suggestion and see how that goes. Thank you everyone!
this didn’t work as i got a “failed to load dev.env” error.
Hey, hope this helps:
- The file
dev.envexists in the same path where yourdocker-compose.ymlis? - Also, if exists, has the required variables mentioned before?
IRemember to fill out all the required values into the env file, not only the 3 provided as an example.
# Example: If the compose file has something like ${GHOST_URL}, your env file must have:
GHOST_URL="https://your-ghost-url.yourdomain"
# etc
