Hi y’all,
I’m seeking guidance on how to effectively implement this rewrite using Nuxt. Any assistance would be greatly appreciated. Thank you in advance.
And
- How was Ghost installed and configured? Hosted
- What Node version, database, OS & browser are you using? Node 18.x
- What errors or information do you see in the console? Failed to resolve DNS path for this host
We’re currently using Nuxt ^2.6.x, and I recently came across this helpful article that outlines the process of rewrite routes from https://flecto.io/blog to https://blog.flecto.io
We’re hosted on Vercel ( Only website, not the Ghost blog )
In our nuxt.config.js file, I’ve incorporated a ProxyMiddleware:
import { createProxyMiddleware } from 'http-proxy-middleware'
const rewriteRules = [
createProxyMiddleware('/blog', {
target: 'https://blog.flecto.io',
changeOrigin: true,
pathRewrite: {
'^/blog': '/'
export default async () => {
serverMiddleware: rewriteRules,
While the page functions as intended, I’ve encountered an issue with images and some CSS not loading properly. They attempt to download from localhost:3000/content/images… or localhost:3000/public/…
Furthermore, I’ve observed that when I include X-Forwarded-Host, the functionality breaks:
changeOrigin: true,
headers: {
'X-Forwarded-Host': BLOG_URL,
pathRewrite: {
'^/blog': '/'
Resulting in:
Domain error
To make sure I understand:
Is the example code you are providing to be run on Vercel, where it will redirect content there to Ghost?
What url does Ghost ‘think’ it’s at? You’ll need Ghost to believe it’s URL is flecto.io/blog (even if it only gets those requests by reverse proxy), if you want it to reliably create links to itself that work.
Not redirect, but rewrite. Both URL will keep working, but the /blog will rewrite the route.
Example: next.config.js Options: rewrites | Next.js
Yeah, as i said, this is working, but i think i need the X-Forwarded-Host to make ghost “think” that it is ghost URL. So i got Failed to resolve DNS path for this host.
Do rewrites issue HTTP redirects or only solve issues when the destination is also served by the same Next.js app?
The error happen when i added: X-Forwarded-Host in headers.
To be more clear, i added this configuration in our Next App Staging Enviroment:
trailingSlash: true,
async headers() {
return [
source: '/blog',
headers: [
key: 'x-forwarded-host',
value: 'https://market.staging.flecto.io/blog',
source: '/blog/:path*',
headers: [
async rewrites() {
return [
source: '/blog',
destination: 'https://blog.flecto.io',
source: '/blog/:path*/',
destination: 'https://blog.flecto.io/:path*/',
When i access the following link: Domain error
I got: Failed to resolve DNS path for this host
Fixing this enviroment, i can try the same approach in Nuxt App.
I have updated the next.config.js with
const ghostRules = [
// https://ghost.org/help/run-ghost-from-a-subdirectory
// Have an X-Forwarded-Host header that matches the custom domain in Ghost(Pro) > Domains
// x-forwarded-host must match your base custom domain set within Ghost Admin - if you're configuring example.com/blog/ then this would be example.com
value: 'https://market.staging.flecto.io',
// Include the X-Forwarded-Proto header set to https not http.
key: 'x-forwarded-proto',
value: 'https',
// Provide a certificate & serve HTTPS traffic.
key: 'x-forwarded-port',
value: '443',
// Include the X-Forwarded-For header, populated with the remote IP of the original request.
key: 'x-forwarded-for',
async headers() {
return [
source: '/blog',
headers: ghostRules,
async rewrites() {
return [
source: '/blog',
But the error with DNS keep the same, do i need to add https://market.staging.flecto.io/blog in the Ghost panel ?
We have Ghost Pro working on a sub-directory on Vercel but so far I believe caching isn’t working Whop | Blog
That’s what i want to do. could you provide an example of your config ?
I receive an email saying that i need to upgrade do enterprise or pay a addon to do that :(
it is possible we may be paying for enterprise, our bill is pretty high! sorry I don’t have access to the config
