- What’s your URL? Site not public
- What version of Ghost are you using? 4.41.3
Ghost is running with docker-compose on a Linode VPS, using the following configuration:
ghost-logs:
image: ghost:4-alpine
volumes:
- ghost-log:/var/lib/ghost/content
restart: always
ports:
- 3003:2368
environment:
# see https://ghost.org/docs/config/#configuration-options
# this url value is just an example, and is likely wrong for your environ>
url: "REDACTED"
mail__transport: "SMTP"
mail__options__service: "Mailgun"
mail__options__host: "smtp.eu.mailgun.org"
mail__options__port: 587
mail__options__auth__user: "<REDACTED>"
mailgun__auth__pass: "<REDACTED>"
Node v14.19.1
Database: SQLite3
Browser: Orion 0.99.113.2-beta
and Safari 15.4
OS: Debian 11 bullseye
When trying to log in to a test account I made:
[2022-03-26 11:52:32] INFO Worker for job "update-check" online
[2022-03-26 11:52:34] INFO Worker for job update-check sent a message: Ran update check
[2022-03-26 11:52:34] INFO Worker for job update-check sent a message: done
[2022-03-26 11:52:51] INFO "GET /" 304 100ms
[2022-03-26 11:52:51] INFO "GET /members/api/member/" 204 2ms
[2022-03-26 11:52:51] INFO "GET /members/api/site/" 200 23ms
[2022-03-26 11:54:18] INFO Worker for job "email-analytics-fetch-latest" online
[2022-03-26 11:54:20] INFO Worker for job email-analytics-fetch-latest sent a message: Fetched 0 events and aggregated stats for 0 emails in 331ms
[2022-03-26 11:54:20] INFO Worker for job email-analytics-fetch-latest sent a message: done
[2022-03-26 11:54:32] INFO "POST /members/api/send-magic-link/" 200 60990ms
[2022-03-26 11:55:31] ERROR Failed to send email. Reason: Connection timeout.
"Please see https://ghost.org/docs/config/#mail for instructions on configuring email."
Error ID:
a35750a0-acfb-11ec-b7d2-e5202f57ba13
Error Code:
ETIMEDOUT
Error: Connection timeout
at createMailError (/var/lib/ghost/versions/4.32.2/core/server/services/mail/GhostMailer.js:67:12)
at SMTPConnection._formatError (/var/lib/ghost/versions/4.32.2/node_modules/nodemailer/lib/smtp-connection/index.js:784:19)
at SMTPConnection._onError (/var/lib/ghost/versions/4.32.2/node_modules/nodemailer/lib/smtp-connection/index.js:770:20)
at Timeout.<anonymous> (/var/lib/ghost/versions/4.32.2/node_modules/nodemailer/lib/smtp-connection/index.js:229:22)
at listOnTimeout (internal/timers.js:557:17)
at processTimers (internal/timers.js:500:7)
- Add your Mailgun credentials to docker-compose through environment variables.
- Create testing Member account
- Try to log into that Member account
- Check the console (
docker-compose logs -f
I have no idea how to even start debugging this. I’ve double-checked my credentials and checked that my mailing ports were open. I also tried using the default SFTP configuration (this is not ideal because of email reputation etc.), but that also resulted in an error (Failed to send email. Reason: Sending failed.
Does anyone have any ideas?
