Everyone is using wordpress, but I chosen ghost. Because it looks more modern, better performance and lighter weight, and let me get rid of Mysql.
But after I installed it and configured s3 storage plugin to compatible with oracle object storage, then I try to wirte my first post, the built-in editor does not work properly with CJK IME.
Before that I even wanted to write a article in Chinese to recommend ghost to those people who have no programming experience, a sorrowful ending.
May I ask what is CJK IME? Never heard of it. THanks
It stands for the input method for Chinese, Japanese, Koren. I think this issue blocks many potential users out from Ghost.
I have fixed this problem and raised a pull request, but not merged maybe caused by the failure of CI test ( I think it is not my problem, but the problem of test environment). But my customized contribution has included this bug fix and works very well on Chrome. (PS: I have passed all the tests via Grunt release command)
Ghost looks cool, but I found the editor is completely unusable with ATOK Japanese IME.
There are many problems. For example, I type “にほんご” without confirming conversion and type ctrl+H to delete it, the characters are repeatedly appears after “にほんご”, finally “にほんごにほんにほに”.
I’m grad if maintainers have plans to support CJK IMEs.
Any places to report these IME bugs?
Hi, any update regarding this input matter? Thanks
