Where does nginx define the root folder of ghost cms?
Hi There,
Can anyone tell me where does the root folder of Ghost is define in nginx?
as even when I comment the root directive and restart nginx, Ghost is still working :thinking:
server {
    listen 443 ssl http2;
    listen [::]:443 ssl http2;
    server_name mysite.com;
    #root /var/www/mysite/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
    ssl_certificate /etc/letsencrypt/mysite/fullchain.cer;
    ssl_certificate_key /etc/letsencrypt/mysite/mysite.key;
    location / {
    location ~ /.well-known {
        allow all;
    location ~ \.php$ {
        include snippets/fastcgi-php.conf;
        fastcgi_pass unix:/run/php/php7.4-fpm.sock;
    client_max_body_size 50m;
  • Ghost version?
    4.34.3 on Linux
Thanks for your help,
What are you trying to do? Your question seems to conflict with the statement that Ghost is still working :wink:
Thanks for your reply.
Well, I try to understand how it works and make my head around. When I use a software (mainly web apps) I like to understand how it works.
Where does Nginx find the instruction to redirect all traffic from mysite.com to
/var/www/mysite/system/nginx-root (which I’m not even sure that this is the public root directory of Ghost as this folder is empty right now).
It have to be define some where…
PS: I already browse the documentation and didn’t find the info.
PS2: This is the first time that I setup a JS web site. All sites that I put in production before were in PHP.
Respond to requests for mysite.com.
For any requests coming in on /*, proxy that request to the Ghost server running on http://127.0.0.1:2368.
There’s no β€œroot folder” as such that you’d see in the typical serving-files-directly setup.
Ok thank you so much for your help.
So now I start to understand. :smiling_face:
Ghost is setup as a nodeJS server on port 2368 which is used by nginx as a proxy.
And now I can list my ghost site using ghost ls
Output
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name                β”‚ Location                     β”‚ Version β”‚ Status               β”‚ URL                         β”‚ Port β”‚ Process Manager β”‚
β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
β”‚ mysite-com          β”‚ /var/www/mysite.com          β”‚ 4.34.3  β”‚ running (production) β”‚ https://mysite.com          β”‚ 2368 β”‚ systemd         β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
And now I get the root folder of my ghost site
I can change the target using:
ghost config [key] [value]
like
ghost config Location \var\www\otherFolder
Is this right?
