Hi. Where in the theme files would I change the default callout color and emoji in posts? I use the same grey, no emoji callout everywhere, and I find it tedious to keep changing the defaults to what I need.
Thanks.
-MP
Thanks.
-MP
You could change the colour through CSS, but changing the emoji isn’t something that would work that way.
However…there are snippets for exactly the use case you have in mind ![]()
Brilliant! Thanks! Works perfectly.
For my education, is it possible in the template?
You can change the colour, but it’s rather an “overlay” of sort.
Adding this CSS would do the trick (though, it would change EVERY callout to the colour you specificy:
.kg-callout-card {
background: #000;
Got it, thanks. So the default values for color and emoji are built into Ghost proper, and not in any of the template files? I searched through them in VSCode and didn’t find any references to "callout” that seemed to apply.
Correct. They are essentially part of the content. The theme gets the content from Ghost and then just displays it.
Thank you. Learning something new every day.
This is how a theme would access the content, if you want to know more:
