Yarn dev failed!
I am trying to run the Ghost Core on my Macbook M1 with the following components:
  • NodeJS LTS/Hydrogen (v18.19.1
  • Yarn (1.22.22)
I was able to run the yarn setup successfully, tables are migrated and records are populated. However when it comes to yarn dev then the following issues happened.
I have tried yarn fix but it doesn’t help.
yarn dev --verbose
yarn run v1.22.22
$ node .github/scripts/dev.js --verbose
Running projects: ghost, ts, admin, adminXDeps, adminX
[adminX]
[adminX]  >  NX   Running target dev for 2 projects and 2 tasks they depend on:
[adminX]
[adminX]     - @tryghost/admin-x-demo
[adminX]     - @tryghost/admin-x-settings
[adminX]
[adminX]
[admin]
[admin] > nx run ghost-admin:dev --live-reload-base-url=/ghost/ --live-reload-port=4201
[admin]
[ghost]
[ghost]  >  NX   Running target dev for project ghost and 12 tasks it depends on:
[ghost]
[ghost]
[adminX]
[adminX] > nx run @tryghost/admin-x-design-system:build  [local cache]
[adminX]
[adminX]
[adminX] > @tryghost/admin-x-design-system@0.0.0 build
[adminX] > concurrently "vite build" "tsc -p tsconfig.declaration.json"
[adminX]
[adminX] [0] vite build exited with code 0
[adminX] [1] tsc -p tsconfig.declaration.json exited with code 0
[ghost]
[ghost] > nx run ghost:dev
[ghost]
[admin] > ghost-admin@5.81.0 dev
[admin] > ember serve --live-reload-base-url=/ghost/ --live-reload-port=4201
[ghost] > ghost@5.81.0 dev
[ghost] > node --watch index.js
[ghost] (node:38380) ExperimentalWarning: Watch mode is an experimental feature and might change at any time
[ghost] (Use `node --trace-warnings ...` to show where the warning was created)
[ghost] [2024-03-26 16:18:35] INFO Ghost is running in development...
[ghost] [2024-03-26 16:18:35] INFO Listening on: 127.0.0.1:2368
[ghost] [2024-03-26 16:18:35] INFO Url configured as: http://localhost:2368/
[ghost] [2024-03-26 16:18:35] INFO Ctrl+C to shut down
[ghost] [2024-03-26 16:18:35] INFO Ghost server started in 0.675s
[ghost] [2024-03-26 16:18:35] INFO Database is in a ready state.
[ghost] [2024-03-26 16:18:35] INFO Ghost database ready in 0.901s
[ghost] [2024-03-26 16:18:36] WARN Missing mail.from config, falling back to a generated email address. Please update your config file and set a valid from address
[adminX]
[adminX] > nx run @tryghost/admin-x-framework:build
[adminX]
[adminX]
[adminX] > @tryghost/admin-x-framework@0.0.0 build
[adminX]
[adminX] [1] src/vite.ts(37,13): error TS2769: No overload matches this call.
[adminX] [1]   The last overload gave the following error.
[adminX] [1]     Type 'Plugin_2' is not assignable to type 'PluginOption'.
[adminX] [1]       Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").Plugin' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").Plugin'.
[adminX] [1]         Types of property 'apply' are incompatible.
[adminX] [1]           Type '"build" | "serve" | ((this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").ConfigEnv) => boolean) | undefined' is not assignable to type '"build" | "serve" | ((this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").ConfigEnv) => boolean) | undefined'.
[adminX] [1]             Type '(this: void, config: UserConfig, env: ConfigEnv) => boolean' is not assignable to type '"build" | "serve" | ((this: void, config: UserConfig, env: ConfigEnv) => boolean) | undefined'.
[adminX] [1]               Type '(this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").ConfigEnv) => boolean' is not assignable to type '(this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").ConfigEnv) => boolean'.
[adminX] [1]                 Types of parameters 'config' and 'config' are incompatible.
[adminX] [1]                   Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").UserConfig' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").UserConfig'.
[adminX] [1]                     Types of property 'plugins' are incompatible.
[adminX] [1]                       Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").PluginOption[] | undefined' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").PluginOption[] | undefined'.
[adminX] [1]                         Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").PluginOption[]' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").PluginOption[]'.
[adminX] [1]                           Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").PluginOption' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").PluginOption'.
[adminX] [1]                               Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").Plugin' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").Plugin'.
[adminX] [1]                                   Type '"build" | "serve" | ((this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").ConfigEnv) => boolean) | undefined' is not assignable to type '"build" | "serve" | ((this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").ConfigEnv) => boolean) | undefined'.
[adminX] [1]                                       Type '(this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").ConfigEnv) => boolean' is not assignable to type '(this: void, config: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").UserConfig, env: import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").ConfigEnv) => boolean'.
[adminX] [1]                                           Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").UserConfig' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").UserConfig'.
[adminX] [1]                                               Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").PluginOption[] | undefined' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").PluginOption[] | undefined'.
[adminX] [1]                                                 Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").PluginOption[]' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").PluginOption[]'.
[adminX] [1]                                                   Type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vite/dist/node/index").PluginOption' is not assignable to type 'import("/Users/themrb/Documents/personal/draphonix/Ghost/node_modules/vitest/node_modules/vite/dist/node/index").PluginOption'.
[adminX] [1]                                                     Type 'PluginOption[]' is not assignable to type 'PluginOption'.
[adminX] [1]                                                           Type 'Plugin_2[]' is not assignable to type 'PluginOption'.
[adminX] [1]                                                             Type 'Plugin_2[]' is not assignable to type 'PluginOption[]'.
[1]                                                               Type 'Plugin_2' is not assignable to type 'PluginOptionx run-many --projects=@tryghost/admin-x-demo,@tryghost/admin-x-settings --parallel=49 --targets=dev exited with code 1
--> Sending SIGTERM to other processes..
[adminXDeps] while [ 1 ]; do nx watch --projects=apps/admin-x-design-system,apps/admin-x-framework -- nx run \$NX_PROJECT_NAME:build; done exited with code SIGTERM
[ts] while [ 1 ]; do nx watch --projects=ghost/bookshelf-repository,ghost/collections,ghost/donations,ghost/email-addresses,ghost/ghost,ghost/in-memory-repository,ghost/mail-events,ghost/model-to-domain-event-interceptor,ghost/nql-filter-expansions,ghost/post-events,ghost/post-revisions,ghost/recommendations -- nx run \$NX_PROJECT_NAME:build:ts; done exited with code SIGTERM
[admin]
[admin]
[admin]
[admin]  >  NX   Running target dev for project ghost-admin failed
[admin]
[admin]    Failed tasks:
[admin]
[admin]    - ghost-admin:dev
[admin]
[admin]    Hint: run the command with --verbose for more details.
[admin]
[admin] nx run ghost-admin:dev --live-reload-base-url=/ghost/ --live-reload-port=4201 exited with code 1
[ghost]
[ghost]
[ghost]
[ghost]  >  NX   Running target dev for project ghost and 12 tasks it depends on failed
[ghost]
[ghost]    Failed tasks:
[ghost]
[ghost]    - ghost:dev
[ghost]
[ghost]    Hint: run the command with --verbose for more details.
[ghost]
[ghost] nx run ghost:dev exited with code 1
Executing dev command failed:
If you've recently done a `yarn main`, dependencies might be out of sync. Try running `yarn fix` to fix this.
If not, something else went wrong. Please report this to the Ghost team.
✨  Done in 3.85s.
any one know this? I have the same issue
I was able to fix yarn dev failing on nx run @tryghost/admin-x-framework:build by downgrading my Node version from ~v22 to LTS iron (v20.19.0):
nvm install lts/iron
npm install -g corepack (yarn install)
yarn fix (clean-up from previous attempts at getting yarn dev working
yarn setup
yarn dev (finally worked using lts/iron)
This was unexpected because the docs say they support LTS jod (22) but in my case that didn’t work out locally on Mac. Hope this helps.
Thank you for that answer, it worked!
