2 conflicting versions of ghost-cli?
$ whereis ghost
ghost: /usr/bin/ghost /usr/local/bin/ghost
$ /usr/local/bin/ghost version
Ghost-CLI version: 1.17.3
Ghost version: 4.48.2 (at /var/www/ghost/www.reposium.com)
$ /usr/bin/ghost version
Love open source? We’re hiring Node.js Engineers to work on Ghost full-time.
https://careers.ghost.org/product-engineer-node-js
Ghost-CLI version: 1.21.0
So, I have 2 versions of the binary ghost installed :
$ ls -l /usr/bin/ghost /usr/local/bin/ghost
lrwxrwxrwx 1 root root 39 Jul 12 01:14 /usr/bin/ghost -> ../lib/node_modules/ghost-cli/bin/ghost
lrwxrwxrwx 1 root root 52 May 24  2021 /usr/local/bin/ghost -> ../share/.config/yarn/global/node_modules/.bin/ghost
by default the /usr/local/bin one is the one chosen (because of my PATH) .
It seems that the problem is coming from a mix of yarn and npm usage ?
$ npm list -g --depth=0
/usr/lib
├── corepack@0.10.0
├── ghost-cli@1.21.0
├── ghost-static-site-generator@1.0.1
├── gulp-cli@2.3.0
└── npm@8.13.2
I think this is the source of this :
$ ghost doctor
✖ Checking system Node.js version - found v16.16.0
✔ Checking logged in user
System checks failed with message: 'Linux version is not Ubuntu 16, 18, or 20'
For local installs we recommend using `ghost install local` instead.
? Continue anyway? Yes
System stack check skipped
ℹ Checking system compatibility [skipped]
+ sudo systemctl is-active ghost_www-reposium-com
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✖ Checking binary dependencies
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v16.16.0
One or more errors occurred.
1) Checking system Node.js version
Message: The version of Node.js you are using is not supported.
Supported: ^10.13.0 || ^12.10.0 || ^14.15.0
Installed: 16.16.0
See https://ghost.org/docs/faq/node-versions/ for more information
2) Checking binary dependencies
Message: The installed node version has changed since Ghost was installed.
Help: Run ghost update 4.48.2 --force to re-install binary dependencies.
    OS: Ubuntu, v21.04
    Node Version: v16.16.0
    Ghost Version: 4.48.2
    Ghost-CLI Version: 1.17.3
    Environment: production
    Command: 'ghost doctor'
Thank you !
This is the problem. Use one or the other. Make sure you set the global prefix, i.e., /usr or /usr/local
Either change your $PATH or the prefix. For the latter, you’ll have to reinstall global packages, so symlinks are recreated.
