502 Error after updating to v2
Getting 502 errors while trying to upload images to our ghost blog. Anyone has seen this error before? Many thanks!
  • Version of Ghost: v2.25 (and v2.27)
  • Configuration:
    DigitalOcean one-click installation
    OS: Ubuntu, v16.04
    Node Version: v10.16.0
    Ghost-CLI Version: 1.11.0
  • Error message in console
    vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:850 POST https://www.domain.com/blog/ghost/api/v2/admin/images/upload/ 502
    send @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:850
    ajax @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:827
    _makeRequest @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8043
    _makeRequest @ ghost.min-abc057d4ff00a31ff766d6e04096d8c6.js:1416
    r @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:2618
    request @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8037
    post @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8052
    _uploadFile (task) @ ghost.min-abc057d4ff00a31ff766d6e04096d8c6.js:495
    _resumeGenerator @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8485
    _handleResolvedContinueValue @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8493
    _proceed @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8486
    _scheduleProceed @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8486
    _start @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8471
    _startTaskInstance @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8457
    _flushQueues @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8454
    schedule @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8447
    _performShared @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8513
    perform @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8512
    _uploadFiles (task) @ ghost.min-abc057d4ff00a31ff766d6e04096d8c6.js:493
    _setFiles @ ghost.min-abc057d4ff00a31ff766d6e04096d8c6.js:485
    r._join @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4276
    r.join @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4241
    h @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:3091
    (anonymous) @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:1403
    a @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:3007
    change @ ghost.min-abc057d4ff00a31ff766d6e04096d8c6.js:114
    trigger @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:2767
    r._run @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4277
    (anonymous) @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:2781
    handleEvent @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:2781
    handleEvent @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:2694
    (anonymous) @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:2719
    dispatch @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:642
    b.handle @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:637
    Show 21 more frames
    vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:10161 Uncaught TypeError: Cannot read property ‘url’ of undefined
    at vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:10161
    at e.value (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:5756)
    at r.updateSrc (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:10161)
    at e.r._join (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4276)
    at e.r.join (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4241)
    at h (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:3091)
    at vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:1403
    at a (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:3007)
    at r.onComplete (vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:1403)
    at r. (ghost.min-abc057d4ff00a31ff766d6e04096d8c6.js:493)
    (anonymous) @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:10161
    value @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:5756
    updateSrc @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:10161
    t.invoke @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4208
    t.flush @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4200
    t.flush @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4213
    r._end @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4275
    r.end @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:4230
    (anonymous) @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:8051
    l @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:558
    fireWith @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:559
    k @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:839
    (anonymous) @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:849
    load (async)
    send @ vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:849
    Show 48 more frames
    vendor.min-b2f8edd0972fea6d8bd360ed183797f6.js:850 PUT https://www.domain.com/blog/ghost/api/v2/admin/posts/5d499c8de15e026333fb5ef7/ 502
Can you share the output from the server side ghost logs? either ghost log or looking in the content/logs folder.
The server side log should have some detail of what the real issue is.
thanks, will have a look now
ghost log looks all normal except occational bootstrap socket warning[2019-08-06 16:00:40] WARN Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED [2019-08-06 16:00:40] WARN Tries: 2 [2019-08-06 16:00:40] WARN Retrying... [2019-08-06 16:00:40] WARN Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED
content/logs/xxxx.error.log also doesn’t seem to have anything related:
Log message
{"name":"Log","hostname":"ghost-1gb-lon1-01","pid":22115,"level":50,"err":{"id":"ff065dd0-b7e2-11e9-b21e-27ab7c4b8eeb","domain":"https://www.perfocal.com/blog","code":"IMAGE_SIZE_URL",$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":22115,"level":50,"err":{"id":"607105b0-b7ee-11e9-b21e-27ab7c4b8eeb","domain":"https://www.perfocal.com/blog","code":"IMAGE_SIZE_URL",$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":22115,"level":50,"err":{"id":"17e6be20-b816-11e9-b21e-27ab7c4b8eeb","domain":"https://www.perfocal.com/blog","code":"IMAGE_SIZE_URL",$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":22115,"level":50,"err":{"id":"a895ed60-b816-11e9-b21e-27ab7c4b8eeb","domain":"https://www.perfocal.com/blog","code":"IMAGE_SIZE_URL",$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25170,"level":50,"req":{"meta":{"requestId":"7ca10212-213d-433d-834c-7c10ee98f38b","userId":null},"url":"/users/me/?include=roles","m$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25170,"level":50,"req":{"meta":{"requestId":"93c137b0-30dd-410a-8997-f662aabdf89c","userId":null},"url":"/users/me/?include=roles","m$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25170,"level":50,"req":{"meta":{"requestId":"25088877-d99e-4a6c-9d05-f592701268de","userId":null},"url":"/users/me/?include=roles","m$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25170,"level":50,"req":{"meta":{"requestId":"d259f43b-a17f-47e6-8a71-de3a6f3b94ad","userId":null},"url":"/users/me/?include=roles","m$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25395,"level":50,"req":{"meta":{"requestId":"ebc8c1f0-b85e-11e9-b180-57ed8e51868a","userId":null},"url":"/posts/?limit=30&page=1&filt$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25640,"level":50,"req":{"meta":{"requestId":"93f45ce0-b85f-11e9-b476-097d946872ea","userId":"5c6c09a7c01ffe7017976daf"},"url":"/posts$ {"name":"Log","hostname":"ghost-1gb-lon1-01","pid":25818,"level":50,"req":{"meta":{"requestId":"b8ca7270-b85f-11e9-b7ec-4d4e6d0b53ce","userId":"5c6c09a7c01ffe7017976daf"},"url":"/posts$ $ons/2.27.0/node_modules/express/lib/application.js:230:10)"},"msg":"Site is starting up, please wait a moment then retry.","time":"2019-08-06T15:50:42.559Z","v":0}
Just realised that I did not paste the full message. But it does not seem to have logged relevant info there?
The blog is up and running, and sends emails with not problem. It’s just image uploading issue. We’ve checked folder permissions, it looks like user ghost has sufficient permissions. Also ghost doctor says everything is good! :thinking:
Many thanks!
All I can see so far is that two requests errored with a 502:
Part way through your stack trace I can see:
And in the error log I can see parts of errors:
“code”:“IMAGE_SIZE_URL”,
This is super weird, but it’s not enough information to debug the problem
Try looking in the non error ghost log, and look for reference to those 2 requests.
You can also try looking in /var/log/nginx/error.log.
Nginx error log:
2019/08/06 19:25:07 [error] 5255#0: *2261264 open() "/opt/statics/public/wp-login.php" failed (2: No such file or directory), client: 197.62.xxx.xx, server: www.domain.com, request: "GET /wp-login.php HTTP/1.1", host: "www.domain.com"
2019/08/06 19:34:09 [error] 5255#0: *2261286 upstream prematurely closed connection while reading response header from upstream, client: 194.75.xxx.xxx, server: www.domain.com, request: "POST /blog/ghost/api/v2/admin/images/upload/ HTTP/2.0", upstream: "http://46.101.xx.xx:2368/blog/ghost/api/v2/admin/images/upload/", host: "www.domain.com", referrer: "https://www.domain.com/blog/ghost/"
So we’re hosing Ghost on a separate droplet (and as a subdirectory). This error log is from the main site’s nginx.
was debugging with ghost run instead of ghost start and it just worked… so weird!! now switching back to ghost start and see…
and now the issue is back… :man_facepalming:
I have the same issue here!
I have the exact same issue. I just updated to 2.31.1. I can’t upload images without a 502 error. When I debug in ghost run it works perfectly. Then I go to ghost start and it 502’s again.
Whenever I try to upload an image it gives me an error and the blog restarts on the server side.
Update: I rolled back my version to 2.30.2 and it started working again.
Hmmm ok - is anyone able to find anything relevant in the Ghost log? Logs are kept in /content/logs.
@Juan_Carlos_Orrego are you also on a subdirectory?
FYI - I tried updating to the latest version again and now I’m getting a specific error from ghost run. I’ve posted the output here: 502 on image upload, but works fine with `ghost run` · Issue #11129 · TryGhost/Ghost · GitHub. I rolled back to 2.30.2 and it works fine.
Nevermind, v.2.34.0 fixed my 500 error issue. However, now my 502 error on image upload (not occuring during ghost run ) is back :frowning:
I am getting the same error. I am running 2.34.0 and the error is returning with a 502.
@ekerstein This is really weird. Can you double check ghost doctor for me, and also take a look at your current/node_modules folder and see if sharp is in there?
@bencstrs is this only on image upload? If not can you please start a new thread with full details and logs?
P.S. @ekerstein I’ve reopened 502 on image upload, but works fine with `ghost run` · Issue #11129 · TryGhost/Ghost · GitHub
Hi Hannah,
Yep it is only on image upload.
