- What’s your URL? This is the easiest way for others to debug your issue. https://blog.jherpers.com
- What version of Ghost are you using? 3.35
- What configuration?
- What browser? edge
- What errors or information do you see in the console? 502 bad gateway. ghost is running
- What steps could someone else take to reproduce the issue you’re having? attempt to access domain
Preface this by saying I am not an advanced developer so excuse any ignorance. I had my site up and running and tried to swap domains. I have since reverted back to the old domain but it is now giving the 502 error. I am using Digital Ocean 1-click and Cloudflare.
I looked through the nginx config files and the ports match which is an issue I saw in another thread.
My encryption is set to full on Cloudflare and I am using the Cloudflare NS which appear to be resolving.
Please help I do not know what to do next to troubleshoot.
I am very concerned I am going to lose all of my posts. Is there a way to export from CLI? I had not backed up my files.
