502 Error - PSA / FYI
Hey, I’m new here, I may have to repost this differently, but I wanted to let my experience be known, in case it helps someone else.
I use CloudPanel, with 2 separate Ghost installs on 2 separate Node.js installs. Everything is fine except after updating my Ubuntu server, updating my CloudPanel server, and updating my Ghost installs, my older site kept giving 502 errors.
Took a lot to finally realize, that it was the Ghost-CLI Version giving me problems. I had to update it to get the full update for Ghost. Now everything works fine.
Just think it’s a good thing to share these things, in case someone else is searching for a similar solution.
Perhaps this will help someone
Thank you
Also, running ghost update is what told me that I needed to update the cli, is there a way to update that with the ghost update? JW
Thanks
Thanks for sharing this, the Ghost CLI mismatch can definitely cause confusing 502 errors after updates. I usually run npm install -g ghost-cli before updating Ghost to avoid that issue. @fnf
