HELO THERE THATS MY
PS E:\ghost> ghost install local
A SystemError occurred.
Message: Current directory is not empty, Ghost cannot be installed here.
OS: Microsoft Windows 10 Enterprise, v10.0.18363
Node Version: v14.15.4
Ghost-CLI Version: 1.15.3
Environment: production
Command: ‘ghost install local’
You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
PS E:\ghost> ghost install local --dir GHOST
√ Checking system Node.js version
√ Checking current folder permissions
√ Checking memory availability
√ Checking free space
√ Checking for latest Ghost version
√ Setting up install directory
\ Downloading and installing Ghost v3.41.2 > Installing dependencies > [4/5] Linking d√ Downloading and installing Ghost v3.41.2
√ Finishing install process
√ Configuring Ghost
√ Setting up instance
× Starting Ghost
One or more errors occurred.
- GhostError
Message:
E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\client.js:235
throw new Error(${message}\n${e.message});
Error: Knex: run
$ npm install sqlite3 --save
Cannot find module ‘sqlite3’
Require stack:
- E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\dialects\sqlite3\index.js
- E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\knex.js
- E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\index.js
- E:\ghost\GHOST\versions\3.41.2\node_modules\knex\knex.js
- E:\ghost\GHOST\versions\3.41.2\core\server\data\db\connection.js
- E:\ghost\GHOST\versions\3.41.2\core\server\index.js
- E:\ghost\GHOST\versions\3.41.2\core\index.js
- E:\ghost\GHOST\versions\3.41.2\index.js
at Client_SQLite3.initializeDriver (E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\client.js:235:13)
at Client_SQLite3.Client (E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\client.js:69:10)
at new Client_SQLite3 (E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\dialects\sqlite3\index.js:17:10)
at Knex (E:\ghost\GHOST\versions\3.41.2\node_modules\knex\lib\knex.js:53:28)
at Object. (E:\ghost\GHOST\versions\3.41.2\core\server\data\db\connection.js:34:20)
at Module._compile (internal/modules/cjs/loader.js:1063:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
at Module.load (internal/modules/cjs/loader.js:928:32)
at Function.Module._load (internal/modules/cjs/loader.js:769:14)
at Module.require (internal/modules/cjs/loader.js:952:19)
at require (internal/modules/cjs/helpers.js:88:18)
at isDatabaseInitialisationRequired (E:\ghost\GHOST\versions\3.41.2\core\server\index.js:187:16)
at makeGhost (E:\ghost\GHOST\versions\3.41.2\core\index.js:13:12)
at Object. (E:\ghost\GHOST\versions\3.41.2\index.js:27:1)
Ghost Version: 3.41.2
Environment: development
Command: ‘ghost install local --dir GHOST’
Additional log info available in: C:\Users\Sharp.ghost\logs\ghost-cli-debug-2021-01-28T08_30_38_296Z.log
and whent try start ghost open a notepad and…
#!/usr/bin/env pwsh
$basedir=Split-Path $MyInvocation.MyCommand.Definition -Parent
$exe=“”
if ($PSVersionTable.PSVersion -lt “6.0” -or $IsWindows) {
Fix case when both the Windows and Linux builds of Node
are installed in the same directory
$exe=“.exe”
$ret=0
if (Test-Path “$basedir/node$exe”) {
& “$basedir/node$exe” “$basedir/node_modules/ghost-cli/bin/ghost” $args
$ret=$LASTEXITCODE
} else {
& “node$exe” “$basedir/node_modules/ghost-cli/bin/ghost” $args
$ret=$LASTEXITCODE
exit $ret
and when try ghost start
PS E:\ghost> ghost start
Working directory is not a recognisable Ghost installation.
adolf <midiaadeli12@gmail.com> در تاریخ پنجشنبه ۲۸ ژانویهٔ ۲۰۲۱ ساعت ۱:۲۰ نوشت:
