A way to mass paywall old posts
Is there a quick way to turn old posts to “Paid Members Only” instead of doing it manually?
This should help, though it is a terminal-based tool:
Specifically this part of the README
On the posts list you can ctrl/cmd click to select posts, or select one then scroll down to load all the posts and shift click the last one to select all of them. You can then right-click a post and choose “Change access”
Thanks Kevin this is helpful too!
