Paid access to newest posts
Hi everyone,
is it possible to set up ghost to have all new posts available only for paid subscribers, but revert to free after, say, two weeks? I’d like to keep my articles freely available, but get some benefit for paid subscribers in form of priority access to new content.
Thanks
I don’t know of any out-of-the-box way to do this.
You can definitely set all new posts to be only accessible by your members by changing the Memberships → Default Post Access setting.
To then change the visibility settings after two weeks, you’ll most likely need an outside solution with a bit of custom code, using the endpoint to update a post. Zapier can’t do that, unfortunately.
So I update it via API? Ok, not what I hoped for, but I can do it this way, thanks :slight_smile:
Yeah, I guess the alternative is doing it manually.
Wouldn’t know of any other automated way.
