ActivityPub with Ghost in a subdirectory
Hi all,
I am very excited about the ActivityPub functionality in Ghost. It seems though that using it is currently not possible if Ghost is used within a subdirectory of the domain it’s running on, and not in the root (www.myblog.com/blog vs. www.myblog.com) – this is stated so at https://ghost.org/help/social-web/
However, there’s no reason, technical or whatever, given why that’s the case. Could anyone shed some light on that limitation? Is it going to change in the future? Is there maybe even a workaround? I’d love to use ActivityPub with my Ghost blog, but moving it out of the subdirectory would suck.
Thanks!
I think it probably relates to some baked-in assumptions about where the content is, when the activitypub service talks to Ghost. You could /possibly/ handle it by proxying.
I’d be happy to proxy things. @Cathy_Sarisky, any hints what exactly may need to be proxied/redirected?
I’ve found the relevant commit in the meantime, but that one also doesn’t give any reasoning…
Ah, interesting. So it’ll need a rewrite, too, I guess.
I’ll get in touch with sagzy, the author of the relevant code portions, he can likely shed some light on that particular limitation. once I know more, I’ll update the thread of course :+1:
I too would prefer to configure my reverse proxy to serve a few required routes on the root domain and keep my ghost instance in its subdirectory, instead of moving the whole blog to its own subdomain.
Hey there. I tried to reach out to sagzy, but didn’t get a reply. @Cathy_Sarisky, do you know if he’s active on the forum or know anyone else who contributed to the ActivityPub code?
Hi @ulrik did you find a solution on this? I want to do the same as you - migrate a Ghost blog to be hosted in a subdirectory, AND maintain activity pub functionality
Is there a way forward? Thanks
