I am currently using easypanel which uses traefik in front of docker as my reverse proxy.
How do I correctly set up traefik for to make activity pub work.
Currently getting this
ERROR Could not get webhook secret for ActivityPub FetchError: invalid json response body at https://pupontech.com/.ghost/activitypub/v1/site reason: Unexpected token ‘<’, "<!DOCTYPE "… is not valid JSON
[2025-08-04 18:27:54] ERROR No webhook secret found - cannot initialise
[2026-01-04 13:29:34] ERROR Could not get webhook secret for ActivityPub FetchError: invalid json response body at ``https://kerscher.li/.ghost/activitypub/v1/si te/ reason: Unexpected token '<', "<!DOCTYPE "... is not valid JSON [2026-01-04 13:29:34] ERROR No webhook secret found - cannot initialise
That are my labels: labels: -"traefik.enable=true" # Match both kerscher.li and www.kerscher.li -"traefik.http.routers.ghost-root.rule=Host(`kerscher.li`) || Host(`www.kerscher.li`)" -"traefik.http.routers.ghost-root.entrypoints=websecure" -"traefik.http.routers.ghost-root.tls.certresolver=letsencrypt" # Redirect www to non-www -"traefik.http.middlewares.root-redirect-www.redirectregex.regex=^https?://www.kerscher.li/(.*)" -"traefik.http.middlewares.root-redirect-www.redirectregex.replacement=https://kerscher.li/$$1" -"traefik.http.routers.ghost-root.middlewares=root-redirect-www" -"traefik.http.routers.ghost-root.priority=1000" -"traefik.http.services.ghost-root.loadbalancer.server.port=2368" -"traefik.docker.network=traefik-public" # ActivityPub Settings -"traefik.http.middlewares.sslheader.headers.customrequestheaders.X-Forwarded-Proto = http" -"traefik.http.routers.ghost-root.service=ghost-server" -"traefik.http.services.ghost-server.loadbalancer.passhostheader=true" # Activity Pub -"traefik.http.services.ghost-activitypub.loadbalancer.passhostheader=true" -"traefik.http.services.ghost-activitypub.loadbalancer.server.url=https://ap.ghost.org" -"traefik.http.routers.ghost-activitypub.entrypoints=websecure" -"traefik.http.routers.ghost-activitypub.service=ghost-activitypub" -"traefik.http.routers.ghost-activitypub.tls=true" -"traefik.http.routers.ghost-activitypub.tls.certresolver=leresolver" -"traefik.http.routers.ghost-activitypub.rule=Host(`kerscher.li`) && (PathPrefix(`/.ghost/activitypub/`) || Path(`/.well-known/webfinger`) || Path(`/.we>
