Adding posts via API using Huginn
I’m trying to add posts with Huginn - GitHub - huginn/huginn: Create agents that monitor and act on your behalf. Your agents are standing by!
Does anyone else use Huginn to add posts and if so could you share a post agent json config?
I have Huginn working fine with other API’s such as Discourse’s API but can’t seem to get Ghost right.
Thanks!
I’d just like to say that Huginn is far better than Zapier so another thing that might be cool is if Ghost could be properly integrated with Huginn like Zapier is.
Just an idea, I hope the devs will give it a try and see what I mean.
