Hey everyone, i want to create API endpoint for insert data from theme to my database how i can implement this?
Can you share your usecase? From a functional perspective, the ask doesn’t make much sense ![]()
Look i have on my theme part, i have search result which i want to save in my custom database fields i already created it, and i want to create api endpoint in which i can request to core and in core i can push the data into my database
// In the custom API endpoint file (ghost/core/server/api/endpoints/custom.js)
module.exports = {
add: {
permissions: true,
query(frame) {
// Extract the data from the request body
const { myData } = frame.data;
// Insert the data into the MySQL database
return knex('my_table')
.insert(myData)
.then(() => {
return { success: true };
.catch((err) => {
return { success: false, error: err.message };
this part of code i found on the internet
To be honest, in these use cases, my suggestion is to create a separate app if you’re trying to reuse the Ghost database (which I suggest you shouldn’t do). You can configure nginx to proxy requests for a certain route to your custom app instead of Ghost.
so the recommend is not go inside the core and do changes in it, am i right?
Yes, that’s correct!
