An unexpected error occurred: \"EACCES: permission denied
- What version of Ghost are you using?
ghost 1.9.2
- What configuration?
ubuntu 18.04
ghost install
:heavy_check_mark: Checking system Node.js version
:heavy_check_mark: Checking logged in user
:heavy_check_mark: Checking operating system compatibility
:heavy_check_mark: Checking for a MySQL installation
:heavy_multiplication_x: Checking for latest Ghost version
A ProcessError occurred.
Message: Command failed: yarn info ghost versions --json
{“type”:“error”,“data”:“An unexpected error occurred: "EACCES: permission denied, scandir ‘/home/cmlanche/.config/yarn/link’".”}
{“type”:“info”,“data”:“If you think this is a bug, please open a bug report with the information provided in "/var/www/ghost/yarn-error.log".”}
{“type”:“info”,“data”:“Visit yarn info | Yarn for documentation about this command.”}
Exit code: 1
OS: Ubuntu, v18.04
Node Version: v8.11.4
Ghost-CLI Version: 1.9.2
Environment: production
Command: ‘ghost install’
Additional log info available in: /home/cmlanche/.ghost/logs/ghost-cli-debug-2018-09-02T07_46_34_082Z.log
I tried twice, and failed with the same error, please help me
problem solved, I donot have the perssion of dir /home/cmlanche/.config,
sudo chown <username>:<username> ~/.config
use it sove it
the install doc(https://docs.ghost.org/docs/install) do not say it need ~/.config permission
This issue is tracked here. We are working on a solution.
