Permission Denied Error while upgrading ghost
Hi Team,
I tried to update ghost to the latest version and got below error
Message: ‘EACCES: permission denied, mkdir ‘/var/www/.ghost’’
My blog url : https://plezna.com
:heavy_multiplication_x: Checking for deprecations
An error occurred.
OS: Ubuntu, v18.04.4 LTS
Node Version: v14.17.1
Ghost Version: 3.16.1
Ghost-CLI Version: 1.17.3
Environment: production
Command: ‘ghost doctor’
A promise was rejected but did not have a .catch() handler:
Error: EACCES: permission denied, mkdir ‘/var/www/.ghost/logs’
at Object.mkdirSync (fs.js:1009:3)
at Object.module.exports.makeDirSync (/usr/lib/node_modules/ghost-cli/node_modules/fs-extra/lib/mkdirs/make-dir.js:101:15)
at System.writeErrorLog (/usr/lib/node_modules/ghost-cli/lib/system.js:361:12)
at UI.error (/usr/lib/node_modules/ghost-cli/lib/ui/index.js:462:40)
at Function._run (/usr/lib/node_modules/ghost-cli/lib/command.js:195:16)
at processTicksAndRejections (internal/process/task_queues.js:95:5)
/usr/lib/node_modules/ghost-cli/lib/bootstrap.js:27
throw reason;
at processTicksAndRejections (internal/process/task_queues.js:95:5) {
errno: -13,
syscall: ‘mkdir’,
code: ‘EACCES’,
path: ‘/var/www/.ghost/logs’
I have tried various options but got no sucess, and now my blog is giving Bad gateway error.
I have installed ghost on aws using another user.
I followed below link to resolve but now my blog doesn’t even work
Please help
Just an update, I am unable to run any ghost command because of this issue now.
Below it the output when I do ls -al /var/www/ghost
drwxrwxrwx 6 plezna plezna 4096 Jun 24 12:47 .
drwxr-xr-x 6 root root 4096 Jun 24 10:40 …
-rw-rw-r-- 1 plezna plezna 111 May 26 2020 .ghost-cli
-rw-rw-r-- 1 plezna plezna 712 Jun 20 13:06 config.production.json
drwxrwxr-x 8 plezna plezna 4096 May 26 2020 content
lrwxrwxrwx 1 plezna plezna 30 May 26 2020 current → /var/www/ghost/versions/3.16.1
drwxrwxr-x 5 plezna plezna 4096 May 27 2020 node_modules
-rw-rw-r-- 1 plezna plezna 990 May 27 2020 package-lock.json
drwxrwxr-x 4 plezna plezna 4096 May 26 2020 system
drwxrwxr-x 3 plezna plezna 4096 May 26 2020 versions
If you followed my instructions then your content folder should be owned by the ghost user, which for me is just ‘ghost’ (some people seem to use ghost-mgr or something?). The outside of that I just have a regular user which is my name and that owns everything else. To make sure all permissions are correct, the steps I took were (assuming your ghost install location is /var/www/ghost and the ghost user is ghost):
# set the owners correctly (assuming you are currently 'plezna')
sudo chown -R $USER:$USER /var/www/ghost
sudo chown -R ghost:ghost /var/www/ghost/content
# set the access permissions
sudo find /var/www/ghost/* -type d -exec chmod 775 {} \;
sudo find /var/www/ghost/* -type f -exec chmod 664 {} \;
I did exactly as you said but I am still not able to move past this error.
Now running ls -al /var/www/ghost gives me
total 36
drwxrwxrwx 6 plezna plezna 4096 Jun 24 15:20 .
drwxr-xr-x 7 root root 4096 Jun 24 16:23 …
drwxrwxr-x 8 ghost ghost 4096 May 26 2020 content
But if I run ghost restart it again gives me
An error occurred.
Command: ‘ghost restart’
at Object.module.exports.makeDirSync (/usr/local/lib/node_modules/ghost-cli/node_modules/fs-extra/lib/mkdirs/make-dir.js:101:15)
at System.writeErrorLog (/usr/local/lib/node_modules/ghost-cli/lib/system.js:361:12)
at UI.error (/usr/local/lib/node_modules/ghost-cli/lib/ui/index.js:462:40)
at Function._run (/usr/local/lib/node_modules/ghost-cli/lib/command.js:195:16)
/usr/local/lib/node_modules/ghost-cli/lib/bootstrap.js:27
throw reason;
errno: -13,
syscall: ‘mkdir’,
code: ‘EACCES’,
Just an update to this. I rebooted my aws instance and my site is back online. However, can’t get past this error and unable to use any ghost commands
