Auth via LDAP or OAuth
Is there a way to make Ghost talk to LDAP server / OAuth server to create new users? We want to host internal Ghost instance and to add all our people as Ghost users keeping their passwords in sync.
Also, we are using Slack, so if it is possible to let people login using their Slack account then it will work too.
Put Ghost behind a login - #3 by i8ramin has a lot more information, but the tl;dr is you can’t do it out of the box, although you can make modifications to the Ghost Core to make it work
Thanks for the prompt response.
