Automatic Post Translation
I’ve been working on GPulse Translate, a tool that helps Ghost publishers automatically translate posts into multiple languages without changing their existing workflow.
It connects directly to Ghost through the Admin API and creates translated versions of your posts while preserving formatting, images, links, tags, and SEO metadata. There’s nothing to install on your server: just connect your Ghost site, choose the target languages, and generate translations directly inside your publication.
A practical example is wardrome.com, where GPulse Translate is used to manage multilingual content more efficiently while keeping the publishing workflow inside Ghost.
For publishers managing multiple Ghost instances, GPulse Translate also supports multisite setups, making it easier to handle translations across different publications from a single workflow.
You can learn more here: Translate
